pnetcdf question
Foucar, James G jgfouca at sandia.gov
Thu Mar 18 13:59:45 CST 2004
Hi Rob, thanks for the reply. i was thinking along the same lines. the
reason i am hestitant to do the:
array 1: 1a 1b 1c 2a 3a 3b 3c 3d 4a 4b 4c
array 2: 3 1 4 3
implementation is because it will require communication between the
processors to figure out what offset they should be writing to. so, right
now i am leaning towards separate variables per process. this will require
me to enter "independent data mode", correct? will this cause me to take a
performance hit?
thanks,
jim
-----Original Message-----
To: Foucar, James G
Cc: 'parallel-netcdf at mcs.anl.gov'
Sent: 3/18/2004 11:42 AM
Subject: Re: pnetcdf question
Hi James,
I can think of a couple of solutions.
One thing that you could do is write two arrays, one consisting of
single
blocks of data (the "a"s and "b"s from your example), then another
describing how those were laid out across processors:
array 2: 3 1 4 3
You could use a record (unlimited) variable for array 1 if you like; as
long as you only use one record variable in a PnetCDF file, performance
should be ok.
Alternatively you could make the array sparse, depending on how big the
variance is between your processes.
Alternatively you could write a variable per process.
Perhaps if you described the data a little more in terms of the logical
structure, we could better help lay the data out in the PnetCDF format
(or
suggest a better format).
Rob
On Wed, 17 Mar 2004, Foucar, James G wrote:
> Hello, I am having trouble figuring out how to implement a disk dump
utility
> using pnetcdf. Each processor is to dump the contents of a certain
array
> into a pnetcdf dataset. the problem is that the size of the array may
vary
> between processors. so, my ideal dataset would look like this:
> processor: 1 2 3 4
> data:      a a a a
>            b   b b
>            c   c c
>                d
> The problem is that the data dimension length is not constant across
> processors however the define-mode functions are collective and must
be
> called with the same values. Does anyone know an elegant way of
getting
> around this problem?
> Thanks,
> James
