Irix 64 nc_test error
Rhoades.Jon Rhoades.Jon at ensco.com
Tue Apr 20 15:40:13 CDT 2004
This is what I get with ./nc_test -v I skipped around my output as I did not want to send it all.
andrew 6# ./nc_test -v
*** Testing ncmpi_strerror ...
ok
*** Testing ncmpi_open ...  0: MPI_File_open error = No such file or directory
        FAILURE at line 94 of test_read.c: ncmpi_open of nonexistent file should have returned system error
        ### 1 FAILURES TESTING ncmpi_open! ###
<SNIP>
*** Testing ncmpi_get_var_long ...
        FAILURE at line 829 of test_get.c: value read not that expected
varid: 3, var_name: i, element number: 0 expect: -20got: -8.16044e+10
varid: 9, var_name: ir, element number: 0 expect: -2.14748e+09got: -9.22337e+18
varid: 9, var_name: ir, element number: 1 expect: 2.14748e+09got: 32767
varid: 15, var_name: i1, element number: 0 expect: -2.14748e+09got: -9.22337e+18
varid: 21, var_name: i2, element number: 0 expect: -2.14748e+09got: -9.22337e+18
varid: 21, var_name: i2, element number: 1 expect: 2.14748e+09got: 32767
varid: 27, var_name: i3, element number: 0 expect: -2.14748e+09got: -9.22337e+18
varid: 27, var_name: i3, element number: 1 expect: 2.14748e+09got: 9.22337e+18
 903 good comparisons.
        ### 286 FAILURES TESTING ncmpi_get_var_long! ###
*** Testing ncmpi_get_var_float ...
 1194 good comparisons.
ok
*** Testing ncmpi_get_var_double ...
 1207 good comparisons.
ok
*** Testing ncmpi_get_var1_text ...
 179 good comparisons.
ok
*** Testing ncmpi_get_var1_short ...
 682 good comparisons.
ok
*** Testing ncmpi_get_var1_int ...
 1189 good comparisons.
ok
*** Testing ncmpi_get_var1_long ...
        FAILURE at line 304 of test_get.c: expected: -20, got: -8.16044E+10
        FAILURE at line 304 of test_get.c: expected: -2.14748E+09, got: -9.22337E+18
        FAILURE at line 304 of test_get.c: expected: 2.14748E+09, got: 9.22337E+18
        ### 286 FAILURES TESTING ncmpi_get_var1_long! ###
*** Testing ncmpi_get_var1_float ...
<SNIP>
*** Testing ncmpi_put_att_long ...
        FAILURE at line 4721 of test_put.c: range error: status = 0
        FAILURE at line 1078 of test_put.c: att. value read not that expected
varid: 3, att_name: i, element number: 1 expect: 2.14748e+09, got: 2.95548e+08
 18 good comparisons.
        ### 3 FAILURES TESTING ncmpi_put_att_long! ###
*** Testing ncmpi_put_att_float ...
 21 good comparisons.
ok
*** Testing ncmpi_put_att_double ...
 27 good comparisons.
ok
*** Testing ncmpi_copy_att ...
 34 good comparisons.
ok
*** Testing ncmpi_rename_att ...
ok
*** Testing ncmpi_del_att ...
ok
*** Testing ncmpi_set_fill ... unimplemented
ok
NOTE: parallel-netcdf expects to see 2 failures
Total number of failures: 2306
andrew 7#
-----Original Message-----
From: Jianwei Li [mailto:jianwei at cheetah.cpdc.ece.northwestern.edu]
Sent: Tuesday, April 20, 2004 2:06 PM
To: Rhoades.Jon
Cc: parallel-netcdf at mcs.anl.gov
Subject: RE: Irix 64 nc_test error
Jon,
The "nc_test" is set to run as follows:
# nc_test -c
# nc_test [-v]
(or use "mpirun -np 1" to run the tests)
Except the "ERROR of ncmpi_open of nonexistent file", you should
get no other FAILURE of tests.
Please let us know if there's any problem more than that.
Thanks!
Jianwei
On Tue, 20 Apr 2004, Rhoades.Jon wrote:
> I made the change and the make works building the executables but when I do a make test in the nc_test dir I get the following.
> andrew 5# make test
> ./nc_test
> *** Testing ncmpi_strerror ... ok
> *** Testing ncmpi_close ... ok
> *** Testing ncmpi_inq ... ok
> *** Testing ncmpi_inq_dimid ... ok
> *** Testing ncmpi_inq_dim ... ok
> *** Testing ncmpi_inq_dimlen ... ok
> *** Testing ncmpi_inq_dimname ... ok
> *** Testing ncmpi_inq_varid ... ok
> *** Testing ncmpi_inq_var ... ok
> *** Testing ncmpi_inq_natts ... ok
> *** Testing ncmpi_inq_ndims ... ok
> *** Testing ncmpi_inq_nvars ... ok
> *** Testing ncmpi_inq_unlimdim ... ok
> *** Testing ncmpi_inq_vardimid ... ok
> *** Testing ncmpi_inq_varname ... ok
> *** Testing ncmpi_inq_varnatts ... ok
> *** Testing ncmpi_inq_varndims ... ok
> *** Testing ncmpi_inq_vartype ... ok
> *** Testing ncmpi_get_var_text ...  179 good comparisons. ok
> *** Testing ncmpi_get_var_short ...  682 good comparisons. ok
> *** Testing ncmpi_get_var_int ...  1189 good comparisons. ok
> It continues with the value read not that expected errors.
> Thanks,
> -Jon Rhoades
> Sent: Monday, April 19, 2004 7:06 PM
> To: parallel-netcdf at mcs.anl.gov; Rhoades.Jon
> Subject: Re: Irix 64 nc_test error
> Hi Jon,
> Thank you for the interest in using PnetCDF and for pointing out this problem!
> The problem occurs because we put different arguement datatype "size_t" for the
> strided access interface than the original netCDF's "ptrdiff_t" that is also
> used in the nc_test. Could you try to replace the "ptrdiff_t" to "size_t" in
> the variable declaration to solve your problem temperarily for now? We'll look
> into the code to further address this problem.
> Thanks!
> Jianwei
> >I am trying to get Parallel Netcdf 0.9.3 installed and when I try to compile
> the test scripts I get the following errors.
> >cc-1164 cc: WARNING File = test_get.c, Line = 2071
> >  Argument of type "ptrdiff_t *" is incompatible with parameter of type
> >          "const size_t *".
> >          err = ncmpi_get_vars_text_all(BAD_ID, i, start, edge, stride, value);
> >I also have compiled MPI V2 and the test scripts for it ran fine. I am running
> on a an SGI O2000 Irix 6.5.  Any help would be appreciated.
> >Thanks,
> >Jon Rhoades, CCNA MCP
> >Deputy Division Manager
> >Information Systems & Technology
> >ENSCO, Inc.
