parallel-netcdf on a linux cluster
John Tannahill tannahill1 at llnl.gov
Thu Sep 11 13:54:56 CDT 2003
Do I possibly need to do something to macros.make before I
make the pnetcdf code?
John Tannahill wrote:
> Tried the suggestion below; still have the same problem.
> William Gropp wrote:
>> At 11:25 AM 9/11/2003 -0700, John Tannahill wrote:
>>> I believe that is the case:
>>> To install pnetcdf, I did:
>>>   setenv MPICC mpiicc
>>>   setenv MPIF77 mpiifc
>> Ah.  This explains the problem.  The GNU autoconf code is using the
>> value of F77.  Try doing
>> setenv F77 ifc
>> setenv CC icc
>> in addition and rebuilding.
>> Bill
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA  94551
925-423-3514
Fax:  925-423-4908
