parallel-netcdf on a linux cluster
John Tannahill tannahill1 at llnl.gov
Thu Sep 11 13:25:43 CDT 2003
I believe that is the case:
To install pnetcdf, I did:
   setenv MPICC mpiicc
   setenv MPIF77 mpiifc
Makefile for test code:
INCDIRS = -I/g/g17/jrt/pnetcdf_mcr/parallel-netcdf-0.9.0/include
LNKDIRS = -L/g/g17/jrt/pnetcdf_mcr/parallel-netcdf-0.9.0/lib
slvwrt:  slvwrt.o
         mpiifc -O3 -xW -tpp7 -Zp16 -ip $(LNKDIRS) -o slvwrt slvwrt.o
-lpnetcdf -lm -lfmpi -lmpi
slvwrt.o:  slvwrt.F
         mpiifc -O3 -xW -tpp7 -Zp16 -ip -cm -w90 -w95 -extend_source
$(INCDIRS) -c slvwrt.F
clean:
         /bin/rm -f slvwrt
         /bin/rm -f slvwrt.o
         /bin/rm -f slvwrt.nc
Robert Latham wrote:
> On Thu, Sep 11, 2003 at 10:28:46AM -0700, John Tannahill wrote:
>>I am trying to run my test codes on a linux cluster here at LLNL
>>(mcr).  I have run into a problem.  It appears that the linker
>>(mpiifc) wants one underscore at the end of the nfmpi function
>>names and pnetcdf has two (used nm)?  Does this make sense and is
>>there a quick fix?
> we can only detect the fortran symbol underscore convention at compile
> time, so unfortunately, your app has to be built with the same
> fortran compiler used to build pnetcdf.
> if that is the case, then  let us know and we'll try to figure out
> what's going on.
> ==rob
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA  94551
925-423-3514
Fax:  925-423-4908
