problems installing 0.9.0
William Gropp gropp at mcs.anl.gov
Wed Sep 3 12:23:56 CDT 2003
At 11:58 AM 9/3/2003 -0500, Rob Ross wrote:
>Is there any reason why we should require that someone define the CXX
>variable?  We don't use the C++ compiler for anything, right?  The
>modified configure.in that I sent to John takes out tests for that, and I
>think we should probably commit this unless there's some reason why we
>need to have the C++ stuff in place.
I've updated the configure to remove the C++ tests and to really enable the
--disable-fortran flag (the version in the 0.9.0 release just eliminates
the sizeof(int)==sizeof(size_t) testing).
Bill
