problems installing 0.9.0
Jianwei Li jianwei at cheetah.cpdc.ece.nwu.edu
Wed Sep 3 11:55:47 CDT 2003
John,
FYI, I passed the configure and compile with:
autoconf
setenv CC xlc
setenv FC xlf
setenv F90 xlf90
setenv CXX xlC
setenv MPICC mpcc_r
setenv MPIF77 mpxlf_r
./configure --prefix=/path/to/installdir
make
make install
Jianwei
On Wed, 3 Sep 2003, John Tannahill wrote:
> Robert,
> When I execute the following script to install 0.9.0 on NERSC's IBM-SP
> (seaborg) =>
> module load gnu
> setenv CC     xlc
> setenv FC     xlf
> setenv MPICC  mpcc_r
> ./configure --prefix=/usr/common/homes/j/jrt/tb2/parallel-netcdf-0.9.0 \
>              --with-mpi=/usr/lpp/ppe.poe/bin
> I get =>
> loading cache ./config.cache
> checking for top-level source-directory
> /u2/jrt/tb2/parallel-netcdf-0.9.0
> checking for a BSD compatible install... /usr/common/usg/gnu/bin/ginstall -c
> checking for m4 preprocessor
> checking for m4... m4
> checking m4 flags... -B10000
> checking for gcc... xlc
> checking whether the C compiler (xlc -O ) works... yes
> checking whether the C compiler (xlc -O ) is a cross-compiler... no
> checking whether we are using GNU C... no
> checking whether xlc accepts -g... yes
> checking for c++... no
> checking for g++... no
> checking for gcc... no
> checking for CC... no
> checking for cxx... no
> checking for cc++... no
> checking for cl... no
> checking whether the C++ compiler (gcc  ) works... no
> configure: error: installation or configuration problem: C++ compiler cannot
> create executables.
> John
> John R. Tannahill
> Lawrence Livermore Nat. Lab.
> P.O. Box 808, M/S L-103
> Livermore, CA  94551
> 925-423-3514
> Fax:  925-423-4908
