add "text" data type support
Jianwei Li jianwei at pop.ece.nwu.edu
Tue Feb 25 18:51:33 CST 2003
rob,
OK. I'm done.
Now, the _text data type is supported in get/put variables.
I have some trouble, however, to build the fortran part.
The error message looks like:
make[3]: Entering directory `/sandbox/jili/parallel-netcdf/src/libf'
make[3]: *** No targets.  Stop.
make[3]: Leaving directory `/sandbox/jili/parallel-netcdf/src/libf'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/sandbox/jili/parallel-netcdf/src'
make[1]: *** [subdir_target] Error 1
make[1]: Leaving directory `/sandbox/jili/parallel-netcdf'
make: *** [src/lib/all] Error 2
Could anyone give me some hint on how to configure/build
the fortran part? Thanks!
Jianwei
>I've been working on compiling netcdf's nc_test program against our
>library.
>There are two calls in the serial netcdf library used by nc_test for
>which i cannot find any parallel-netcdf analog
>nc_put_vara_text
>nc_get_var1_text
>Suggestions?
>I've made a bunch of other smaller changes, which i'll write up as a
>rough "porting guide" once i finish actually porting a netcdf
>application :>
>==rob
>Rob Latham
>Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
>Argonne National Labs, IL USA                B29D F333 664A 4280 315B
