[Nek5000-users] Problems in getting eigenvalues using ARNOLDI
Sun Sep 30 06:32:19 CDT 2018
Hi Nek,
  I am running  ARNOLDI simulation case for a flow over a 2D cylinder using
ARPACK . My domain is [-50,50] and Re=50. I have calculated base flow using
SFD method. While calculating Eigen values I have to run the restart around
16-20 times to get an eigenvalues.txt file as an output.
Also the eigenvalues that are coming most of them has zero rotation i.e.,
they are negative real value. Suppose I want to have 30 eigenvalues as an
output and I am setting Krylov subspace as 90 then I am getting around 20
of eigenvalues having zero rotation.
Kindly help as I am stuck in it for long. Thanks in advance.
 Alok Mishra
            Aerospace Department IIT Kanpur
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180930/d0e228ef/attachment.html>
