[Nek5000-users] info
Wed Sep 26 17:45:03 CDT 2018
I have to learn what shells are first, then I can start with the basics. :-)
We, humans, generally install programs using pkg files.
If you wish to tell me where to look for info about shells It would be really nice.
Thank you very much for your help and goodnight from UK, from Leeds to be precise.
Kind Regards
Federico
> On 26 Sep 2018, at 23:21, "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov> wrote:
> We try hard to help beginners to get started but it seems like you have to learn some shell basics first.
> Did you check if the file exists?
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Thursday 27th September 2018 0:15
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] info
>> I have used your version of the code and the on-line version and I get the same error.
>> <br class="" />
>> Last login: Wed Sep 26 23:07:14 on ttys000
>> MacBook-di-Federico-Antonelli:~ maitai2005$ cd ~
>> MacBook-di-Federico-Antonelli:~ maitai2005$ tar -xvzf Nek5000_X.Y.tar.gz
>> tar: Error opening archive: Failed to open 'Nek5000_X.Y.tar.gz'
>> MacBook-di-Federico-Antonelli:~ maitai2005$ tar -zxvf Nek5000-v17.0.tar.gz
>> tar: Error opening archive: Failed to open 'Nek5000-v17.0.tar.gz'
>> On 26 Sep 2018, at 23:01,
>> nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>> <br class="Apple-interchange-newline" />
>> First you download the code e.g. using<br class="" />
>> wget
>> https://github.com/Nek5000/Nek5000/releases/download/v17.0/Nek5000-v17.0.tar.gz <https://github.com/Nek5000/Nek5000/releases/download/v17.0/Nek5000-v17.0.tar.gz><br class="" />
>> <br class="" />
>> Then untar the file<br class="" />
>> tar -zxvf Nek5000-v17.0.tar.gz<br class="" />
>> <br class="" />
>> <br class="" />
>> -----Original message-----<br class="" />
>> From:nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>><br class="" />
>> Sent: Wednesday 26th September 2018 23:56<br class="" />
>> To: nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov><br class="" />
>> Subject: Re: [Nek5000-users] info<br class="" />
>> <br class="" />
>> I had gcc and gfortran installed already.<br class="" />
>> <br class="" /><br class="" />
>> I have installed open-mpi<br class="" />
>> It still does not work.<br class="" />
>> I have followed the instructions, however I had to change the second line dragging the tar file from the desktop to the terminal otherwise I would have got the following error:<br class="" />
>> tar: Error opening archive: Failed to open ‘Nek5000_X.Y.tar.gz'<br class="" />
>> Is the software supposed to open after the line run?<br class="" />
>> Kind regards <br class="" />
>> Federico<br class="" />
>> On 26 Sep 2018, at 21:33, <br class="" />
>> nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:<br class="" />
>> <br class="Apple-interchange-newline" /><br class="" />
>> To install the GNU C/Fortran compilers  MPI, just run<br class="" /><br class="" />
>> brew install gcc<br class="" /><br class="" />
>> brew install gfortran<br class="" /><br class="" />
>> brew install open-mpi<br class="" /><br class="" />
>> To compile and run Nek5000 just follow the instructions outlined in:<br class="" /><br class="" />
>> http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation <http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation> <http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation <http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation>><br
>> -----Original message-----<br class="" /><br class="" />
>> From:nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>><br class="" /><br class="" />
>> Sent: Wednesday 26th September 2018 22:26<br class="" /><br class="" />
>> To: nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov><br class="" /><br class="" />
>> Subject: Re: [Nek5000-users] info<br class="" /><br class="" />
>> No I haven't installed the software below but I will do. I have tried to install it using the terminal but unsuccessfully, I do not have a great knowledge of it, I have tried with Homebrew.On-line I found a sequence of instructions about installation on ubuntu.<br class="" />
>> Something like that would be really useful. <br class="" /><br class="" />
>> Thank you for your replies.<br class="" /><br class="" />
>> Kind Regards<br class="" /><br class="" />
>> Federico <br class="" /><br class="" />
>> On 26 Sep 2018, at 17:44, "nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>" <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:<br class="" /><br class="" />
>> Can you please be more specific. How do the "difficulties" manifest itself?<br class="" /><br class="" />
>> Sent: Wednesday 26th September 2018 18:39<br class="" /><br class="" />
>> Subject: [Nek5000-users] info<br class="" /><br class="" />
>> Hi,<br class="" /><br class="" />
>> I am having difficulties with installing the software on a Mac.<br class="" /><br class="" />
>> I would like to know if somebody can provide some help please.<br class="" /><br class="" />
>> I have read the documents already.<br class="" /><br class="" />
>> Thank you.<br class="" /><br class="" />
>> Federico<br class="" /><br class="" />
>> _______________________________________________<br class="" /><br class="" />
>> Nek5000-users mailing list<br class="" /><br class="" />
>> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov><br class="" /><br class="" />
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users><br class="" /><br class="" />
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users<br class="" />
>> <br class="" />
