[Nek5000-users] Question about tolerance
Wed Sep 26 11:42:34 CDT 2018
No, the answer is in why they are different, not why there are two tolerances. Because, it seems that tolerance 10^-4 for the pressure means the tolerance 10^-4 for the velocity, but in .par file it is 10^-6 for the velocity.
среда, 26 сентября 2018 г., 17:24 +0700 от nek5000-users at lists.mcs.anl.gov  <nek5000-users at lists.mcs.anl.gov>:
>There are two solvers -> two tolerances.
>-----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov < nek5000-users at lists.mcs.anl.gov >
>> Sent: Wednesday 26th September 2018 11:27
>> To: nek5000-users < nek5000-users at lists.mcs.anl.gov >
>> Subject: [Nek5000-users] Question about tolerance
>> Hi, Neks!
>> I'm wonder why in .par file, for example in the turbChannel case, there are different tolerances for pressure and for velocity? I mean that velocity seems to be dependent on pressure field, and if it is 10^-4 tolerance for the pressure, it will automatically the same for the velocity?
>> Best regards,
>> Vlad
>> Nek5000-users mailing list
>>  Nek5000-users at lists.mcs.anl.gov
>>  https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180926/7a033874/attachment.html>
