[Nek5000-users] rst to ix iy iz
Wed Sep 19 21:52:56 CDT 2018
yes, I think that for Lagrangian particle tracking such a regularisation
is absolutely needed such that the force field is smooth, and peaks in
the actual location of the particle. Depending on the function one uses
to distribute the force, one does not need to calculate the indices.
There are a couple of references in the literature that do such an
approach, see e.g. Zhao, Andersson and Gillissen, 2010.
Philipp
On 2018-09-19 21:06, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Philipp,
> Thanks for your your suggestion to correct my model which I really
> appreciate. I want to explain what I am doing and could you please give
> me some advice. Thanks so much.
> Now I am doing a Lagrangian particle tracking model with two-way
> coupling. So the interaction between two phases in my mind, should be
> added to the Eulerian grid point where the particle is, and the grid
> point where it belongs to is what I was finding out. I am sorry to say
> that I don't totally understand the the regularising the force among a
> number of grid points. I read some IBM papers before. If I were correct,
> I think the regularised function is employed with interpolating velocity
> and regularising force among adjacent grid points to keep the interface
> smooth. Do you think for my piont-particle tracking the regularising is
> needed? Would you please give me any suggestions?
> Kind regards,
> Jian
> Nek5000-users mailing list
