[Nek5000-users] Proper setup for AMG solver
Mon Sep 10 06:12:49 CDT 2018
The slow AMG problem he reported was related to an old (buggy) version of amg_hypre. Note, in my experience AMG is faster at least for non-power-of-two ranks (quite common today) independent of the problem size.
Regarding OIFS it’s important to use BDF2 with a possible low lxd otherwise it’s quite expensive. It depends heavily on how expensive the pressure solve is.
Cheers
Stefan
> On 10 Sep 2018, at 12:51, "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Steffen,
> It is interesting that you find that the characteristic scheme is indeed
> faster; similar tests with a a pipe (a few years ago) have shown the
> opposite, which is why we ran our 2013 pipe using conventional time
> steppers. But I guess we should re-do these tests!
> I think your question regarding the temporal evolution is interesting,
> and I guess in the end this has to be judged using physical time scales
> (which scale in plus units for the velocity here). Not being too
> familiar with the characteristic scheme, what is really the smallest
> resolved time scale? Is it the actual time step, or the RK steps, or
> some intermediate scale?
> We have found that AMG is indeed surpassing XXT at some point, but I
> guess this is machine dependent (and number of processors in addition to
> number of elements). Do you have any issues with the setup of XXT taking
> quite some time?
> Best,
> Philipp
>> On 2018-09-02 12:05, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello Stefan & Paul,
>> thanks for your suggestions. I use Nek5000 v17 (mver 17.0.4 in makenek).
>> I have taken a closer look at the logfiles as suggested by Paul. It seems like I spend the most time for the scalar fields second most for the velocity fields and pressure solve is the smallest share. The numbers below are in seconds for a typical timestep without calculating statistics or writing out files at Re_b = 5300 (Re_t = u_t D / nu = 360, 768 cores) and Re_b = 37700 (Re_t = 2000, 6144 cores).
>> I use projection for all 10 scalar fields.
>> 360:
>> Scalars done        0.064
>> Fluid done        0.039
>> U-PRES gmres        0.021
>> Step            0.127
>> 2000:
>> Scalars done        0.94
>> Fluid done        0.51
>> U-PRES gmres        0.21
>> Step            1.72
>> Paul, could you elaborate on why you would not use characteristics when running 10 scalar fields?
>> In my short tests at Re_b=5300, it appears to be more time consuming per step but due to the increase in DT it is worth it to go to characteristics. The time per timestep for targetCFL=2.0 increases by a factor of 3 but DT is increased by a factor of 6.
>> Besides, are such increased timesteps still small enough to capture the temporal evolution of the flow?
>> When I am back on my workstation, I will create a different mesh with lx1=8, lxd=10 and run with the settings Stefan suggested. I expect to get a significant speedup when using the lower tolerances also for velocity and scalars and changing to characteristics.
>> I know about the limit of 350k elements for XXT as I have once commented out the part of the code where this is tested.
>> Since for my setups AMG was always slower than XXT, I am thinking about sticking to XXT.
>> Is there any other reason than your experience with AMG and XXT at large number of elements to enforce AMG?
>> Best Regards,
>> Steffen
>> Message: 5
>> Date: Sat, 1 Sep 2018 17:10:54 +0200
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov     <nek5000-users at lists.mcs.anl.gov>
>> Subject: Re: [Nek5000-users] Proper setup for AMG solver
>> Message-ID:
>>         <mailman.9805.1535814716.86639.nek5000-users at lists.mcs.anl.gov>
>> Content-Type: text/plain; charset=utf-8
>> Try to use
>> lx1=8/lxd=10 with a (potentially) finer mesh
>> BDF2 + OIFS with a targetCFL=3.5
>> set dt = 0 (this will adjust dt to targetCFL)
>> pressure tol = 1e-5 (residual projection turned on) 1e-6 for velocity and scalars (residual projection turned off)
>> Note, a mesh with more than 350k elements requires AMG. The default parameters are fine.
>> What version of Nek5000 are you using?
>> Cheers,
>> Stefan
>> -----Original message-----
>>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>>> Sent: Saturday 1st September 2018 16:50
>>> Subject: [Nek5000-users] Proper setup for AMG solver
>>> Dear Nek users & experts,
>>> I am currently running a turbulent pipe flow very similar to the simulations from El Khoury et al 2013.
>>> Additionally, I solve for 10 thermal fields being treated as passive scalars.
>>> The Reynolds number is the same as the highest in El Khoury (2013), Re_b = 37700.
>>> As I am using the relaxation term filtering (RT-Filter), I have a slightly lower resolution of about 250,000 elements at N=11 (5 times less than El Khoury).
>>> As the simulation is still very heavy, I have been looking into ways for speeding it up.
>>> I found some good suggestions here:
>>> http://nek5000.github.io/NekDoc/faq.html?highlight=amg#computational-speed
>>> and here (older version?)
>>> http://nek5000.github.io/NekDoc/large_scale.html
>>> However, I have some questions regarding these suggestions.
>>> 1) Dealiasing:
>>> Usually I use lxd = 3/2*lx1. Can I lower that or even use lxd=lx1?
>>> 2) Tolerances:
>>> I have tested to reduce the tolerance for pressure from 1e-8 to 5e-5 for a run at Re_b=5300 without any significant speedup. Would you consider 5e-5 for pressure accurate enough for evaluating statistics like turbulent kinetic energy budgets, Reynolds shear
>>>  stress budgets or budget of turbulent heat fluxes?
>>> 3) Time discretisation: BDF2 and OIFS with Courant=2-5
>>> If I go from BDF3/EXT3 at C=0.5 to BDF2/OIFS at C=5.0, will I not miss high frequency fluctuations in time, since DT is much larger?
>>> 4) AMG instead of XXT:
>>> I have tested AMG instead of XXT for both Re_b=5300 and Re_b=37700 without any speedup. Time/timestep is even higher with AMG. My workflow looks like this
>>> 4.1) Set SEMG_AMG in the par file.
>>> 4.2) Run the simulation once to dump amg files.
>>> 4.3) Run amg_hypre (Here I do not know which options to choose, thus I have only uses default settings)
>>> 4.4) Run the simulation.
>>> Maybe I should choose different options for amg_hypre, or should I rather use the amg_matlab2 tools? For the matlab tools I have not found an explanation on how to use them.
>>> I am grateful for any advice regarding these aspects.
>>> Best Regards,
>>> Steffen
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Message: 6
>> Date: Sat, 1 Sep 2018 15:15:29 +0000
>> To: "nek5000-users at lists.mcs.anl.gov"
>> Message-ID:
>>         <mailman.9806.1535814932.86639.nek5000-users at lists.mcs.anl.gov>
>> Content-Type: text/plain; charset="us-ascii"
>> How much time are you spending in your scalar fields?
>> Do you have projection turned on for all these fields?
>> grep tep logfile
>> will tell you how much time per step
>> grep gmr logfile will tell you how much time in the pressure on each step
>> What's left over is mostly passive scalar, unless you are using characteristics.
>> I would not recommend characteristics when running 10 scalar fields.
>> Paul
>> From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Saturday, September 1, 2018 9:50:38 AM
>> 1) Dealiasing:
>> 2) Tolerances:
>> I have tested to reduce the tolerance for pressure from 1e-8 to 5e-5 for a run at Re_b=5300 without any significant speedup. Would you consider 5e-5 for pressure accurate enough for evaluating statistics like turbulent kinetic energy budgets, Reynolds shear stress budgets or budget of turbulent heat fluxes?
>> Best Regards,
>> Steffen
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180901/62611526/attachment.html>
>> Subject: Digest Footer
>> End of Nek5000-users Digest, Vol 115, Issue 1
