[Nek5000-users] Double Precision
Fri Nov 2 04:05:34 CDT 2018
double precision for Nek means 8 bytes (64bit) per number, which
corresponds to an epsilon of 1e-16; internally everything is run with
double precision. So yes, tolerances below 1e-8 are possible, and the
typical files are written with 16 digits (which can however be changed
with the parameters).
Philipp
On 2018-11-02 08:50, nek5000-users--- via Nek5000-users wrote:
> Hi, Neks!
> Could I set tolerances less than 10^-8 in solvers via .par or .rea file,
> or 10^-8 is the minimum? In documentation "double precision" means 8
> digits, but could Nek5000 write files with 16 digits?
> Best regards,
> Mark
> Nek5000-users mailing list
