[Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
Thu May 31 09:28:59 CDT 2018
you have to add the print statement before you enter the if statements.
Marco
On May 31, 2018, at 10:25 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
c-----------------------------------------------------------------------
      subroutine usrdat
      include 'SIZE'
      include 'TOTAL'
      do i=1,nelt
        do j=1,2*ndim
          if(bc(5,j,i,1).eq.1) then
            cbc(j,i,1)='O  '
            write (6,1) j,i,nelt,ndim,bc(5,j,i,1)
1           format(i4,i4,i4,i4,7f20.8)
          elseif(bc(5,j,i,1).eq.2) then
            cbc(j,i,1)='W  '
            write (6,2) j,i,nelt,ndim,bc(5,j,i,1)
2           format(i4,i4,i4,i4,7f20.8)
          elseif(bc(5,j,i,1).eq.3) then
            cbc(j,i,1)='W  '
            write (6,3) j,i,nelt,ndim,bc(5,j,i,1)
3           format(i4,i4,i4,i4,7f20.8)
          elseif(bc(5,j,i,1).eq.4) then
            cbc(j,i,1)='W  '
            write (6,4) j,i,nelt,ndim,bc(5,j,i,1)
4           format(i4,i4,i4,i4,7f20.8)
          elseif(bc(5,j,i,1).eq.5) then
            cbc(j,i,1)='V  '
            write (6,5) j,i,nelt,ndim,bc(5,j,i,1)
5           format(i4,i4,i4,i4,7f20.8)
          elseif(bc(5,j,i,1).eq.6) then
            cbc(j,i,1)='W  '
            write (6,6) j,i,nelt,ndim,bc(5,j,i,1)
6           format(i4,i4,i4,i4,7f20.8)
          else
            cbc(j,i,1)='E  '
            write (6,7) j,i,nelt,ndim,bc(5,j,i,1)
7           format(i4,i4,i4,i4,7f20.8)
          endif
        enddo
      enddo
      call gen_rea(0)
      call exit
      return
      end
i used this and only bold lines of code are executed at every time step and a small piece of the results is shown below
   1 9991000   3          0.00000000
   2 9991000   3          0.00000000
   3 9991000   3          0.00000000
   4 9991000   3          0.00000000
   5 9991000   3          0.00000000
   6 9991000   3          0.00000000
Thank you
Sijo
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
Envoyé: Jeudi 31 Mai 2018 16:12:12
Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
You should output values of i, j, next, ndim and bc(5,j,i,1) for sanity check.
Marco
On May 31, 2018, at 10:07 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
When I checked the loop I can see that only the bold letter codes are executing in all the iteration.
      subroutine usrdat
      include 'SIZE'
      include 'TOTAL'
      do i=1,nelt
        do j=1,2*ndim
            cbc(j,i,1)='O  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='V  '
            cbc(j,i,1)='W  '
          else
            cbc(j,i,1)='E  '
          endif
        enddo
      enddo
      call gen_rea(0)
      call exit
      return
      end
Thanks
Sijo
Envoyé: Jeudi 31 Mai 2018 15:54:04
It probably means that the boundary conditions are not correctly set in usrdat(). Can you add a write statement in each line of the do loop to check wether boundary conditions are properly set when running?
Also add ‘call exist’ after setting the boundary conditions that way Nek5000 will automatically exit.
Marco
On May 31, 2018, at 9:51 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Yes. I see the problem now.
it shows there is 1000 elements but all the co ordinates are  zero. In fact there is nothing and all the boundary conditions are E.
Could you please tell me where i am probably wrong?  It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well.
Regards
Sijo
Envoyé: Jeudi 31 Mai 2018 15:43:20
Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions.
Marco
On May 31, 2018, at 9:37 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
I generated again it didnt work.
I will explain what I did so far.
I made a cube fluid mesh in ICEM.
Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1,   inlet = Sideset no : 5 , Wall_up = Sideset no:4  ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2
After that I exported the mesh from ICEM to exodus.exo format file.
Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors).
Then I mapped the file into exodus.ma2 file.
Then from example Turbulent channel I took a .par file to give parameters.
Now I also given the B.Cs through the .usr file.
 as follows:
      subroutine usrdat
      include 'SIZE'
      include 'TOTAL'
      do i=1,nelt
        do j=1,2*ndim
            cbc(j,i,1)='O  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='V  '
            cbc(j,i,1)='W  '
          else
            cbc(j,i,1)='E  '
          endif
        enddo
      enddo
      return
      end
Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before.
Could you please tell me, if therer is anything wrong?
Thank you
Envoyé: Jeudi 31 Mai 2018 15:22:49
Did you generate a new map file after changing the BCs?
This matters when switching periodic bcs on or off...
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>> on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
Sent: Thursday, May 31, 2018 8:12:55 AM
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs.
Marco
On May 31, 2018, at 9:11 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Marco,
I tried and it compiled . But before starting the time step it failed.
Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls.
I get this error:
Matrix:   0 aa         6       6       6
  0 aa     8.33333E+01  -4.87842E+01   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00
  0 aa    -4.87842E+01   8.66667E+01  -4.87842E+01   7.11752E+00  -1.66667E+00   0.00000E+00
  0 aa     0.00000E+00  -4.87842E+01   8.33333E+01  -4.16667E+01   7.11752E+00   0.00000E+00
  0 aa     0.00000E+00   7.11752E+00  -4.16667E+01   8.33333E+01  -4.87842E+01   0.00000E+00
  0 aa     0.00000E+00  -1.66667E+00   7.11752E+00  -4.87842E+01      Infinity     -Infinity
  0 aa     0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00     -Infinity      Infinity
Matrix:   0 bb         6       6       6
  0 bb     4.16667E-02   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00
  0 bb     0.00000E+00   1.66667E-02   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00
  0 bb     0.00000E+00   0.00000E+00   4.16667E-02   0.00000E+00   0.00000E+00   0.00000E+00
  0 bb     0.00000E+00   0.00000E+00   0.00000E+00   4.16667E-02   0.00000E+00   0.00000E+00
  0 bb     0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00   8.33333E-03   0.00000E+00
  0 bb     0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00
Matrix:   0 Aeig       6       6       6
  0 Aeig   8.33333E+01  -4.87842E+01   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00
  0 Aeig  -4.87842E+01   8.66667E+01  -4.87842E+01   7.11752E+00  -1.66667E+00   0.00000E+00
  0 Aeig   0.00000E+00  -4.87842E+01   8.33333E+01  -4.16667E+01   7.11752E+00   0.00000E+00
  0 Aeig   0.00000E+00   7.11752E+00  -4.16667E+01   8.33333E+01  -4.87842E+01   0.00000E+00
  0 Aeig   0.00000E+00  -1.66667E+00   7.11752E+00  -4.87842E+01      Infinity     -Infinity
  0 Aeig   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00     -Infinity      Infinity
Matrix:   0 Deig       1       6       6
  0 Deig   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00   0.00000E+00
 Error in generalev, info=          12           6          -6
an error occured: dying ...
Could you please tell me why?
Thank you
Sijo GEORGE
Envoyé: Jeudi 31 Mai 2018 14:52:40
I specify the boundary conditions in the usrdat subroutine using the following piece of code
      do i=1,nelt
        do j=1,2*ndim
            cbc(j,i,1)='mv  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='W  '
            cbc(j,i,1)='W  '
          else
            cbc(j,i,1)='E  '
          endif
        enddo
      enddo
Marco
On May 31, 2018, at 8:50 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Neks,
I did the conversion of a mesh from ICEM to exodus file then to re2 file.
But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format.
So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format.
Thank you
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180531/7c253f64/attachment-0001.html>
