[Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
Thu May 31 08:11:22 CDT 2018
Hi Marco,
I tried and it compiled . But before starting the time step it failed.
Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls.
I get this error:
Matrix: 0 aa 6 6 6
0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00
0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00
0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00
0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00
0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity
0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity
Matrix: 0 bb 6 6 6
0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00
0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00
0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00
0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00
0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00
0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00
Matrix: 0 Aeig 6 6 6
0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00
0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00
0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00
0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00
0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity
0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity
Matrix: 0 Deig 1 6 6
0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00
Error in generalev, info= 12 6 -6
an error occured: dying ...
Could you please tell me why?
Thank you
Sijo GEORGE
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Jeudi 31 Mai 2018 14:52:40
Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
I specify the boundary conditions in the usrdat subroutine using the following piece of code
do i=1,nelt
do j=1,2*ndim
if(bc(5,j,i,1).eq.1) then
cbc(j,i,1)='mv '
elseif(bc(5,j,i,1).eq.2) then
cbc(j,i,1)='W '
elseif(bc(5,j,i,1).eq.3) then
cbc(j,i,1)='W '
elseif(bc(5,j,i,1).eq.4) then
cbc(j,i,1)='W '
else
cbc(j,i,1)='E '
endif
enddo
enddo
Marco
On May 31, 2018, at 8:50 AM, [ mailto:nek5000-users at lists.mcs.anl.gov |
nek5000-users at lists.mcs.anl.gov ] wrote:
Hi Neks,
I did the conversion of a mesh from ICEM to exodus file then to re2 file.
But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format.
So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format.
Thank you
Nek5000-users mailing list
[ mailto:Nek5000-users at lists.mcs.anl.gov | Nek5000-users at lists.mcs.anl.gov ]
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180531/9f21871d/attachment.html>
