[Nek5000-users] Using Cartesian grid lookup table in Nekton
Sat May 26 21:54:20 CDT 2018
Hi Saikat,
You can always do the reading from the look up table from .usr file, at
once then feed the data to your ffx ffy and ffz through a common block.
On Thu, May 24, 2018 at 10:55 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hey all,
> Just following up on the query. Would appreciate any input.
> Thanks,
> Saikat
> Saikat Mukherjee,
> PhD Student,
> Paul Research Group - http://www.me.vt.edu/mpaul/
> Engineering Science and Mechanics,
> Virginia Tech.
> On Tue, May 22, 2018 at 4:47 PM, Saikat Mukherjee <msaikat6 at vt.edu> wrote:
>> Hey Neks,
>> I have a forcing function which is in the form of a look up table in X-Y
>> cartesian grid. I would like to use this forcing function in the 2-D fluid
>> momentum equation that Nekton solves. Is there a way to do this in the .usr
>> file or elsewhere?
>> Thanks,
>> Saikat
>> Saikat Mukherjee,
>> PhD Student,
>> Virginia Tech.
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180526/d037ca10/attachment.html>
