[Nek5000-users] Mesh optimisation for the cylinder case ext_cyl
Tue May 22 02:21:32 CDT 2018
Dear Nek5000 masters,
I have been able to run the ext_cyl example. And, after postprocessing the case, it made me wonder if Nek5000 is able to run this case with a more optimized mesh? That is, refined just close to the cylinder and coarse away from it.
Clearly, for this case, the refinement around the cylinder extends in sort of a “+” shape away from the cylinder. This refinement away from the cylinder is not necessary, specially towards the sides and towards the upstream. But even in the downstream the mesh could be (ideally) a bit coarser.
Some other CFD codes are able to handle this problem by accepting refinement of the mesh just close to the cylinder (obviously at the surface of the refinement an element from the coarser side becomes neighbour of two or more elements on the refined side). I’m wondering if Nek5000 is already capable of handling this kind of refinement (or possibly any other solution/trick {maybe lowering the order of the elements themselves}) in order to avoid this typical problem of excessive refinement where it’s not needed/desired?
Wondering and hoping, indeed, because this problem may become serious for some other configurations, for example for an array of cylinders, which then my cause the mesh to be refined all over the domain and not just in the “+” shape region.
Thanks a lot,
Alexis
Dr Alexis Espinosa
Supercomputing Specialist
Pawsey Supercomputing Centre
26 Dick Perry Ave
Kensington  WA  6151
Australia
Tel  +61 xxxx xxxx
Email  alexis.espinosa at pawsey.org.au
Web  www.pawsey.org.au
From: Alexis Espinosa Gayosso <alexis.espinosa at pawsey.org.au>
Date: Tuesday, 8 May 2018 at 4:46 pm
To: <nek5000-users at lists.mcs.anl.gov>
Subject: Compiling Problems in "Running your very first simulation"
Hello,
The title of my thread is the same as for an already existing thread (26-Sept-2017) because:
I receive very similar warning messages when compiling nek5000 (./maketools all). Lots of warnings!
>From your answer on that thread it seems that you do not worry at all for the warning messages. Should we really not care about them? How to know which warnings are not of concern and which other are? Can you post your own .log file to see which warning messages are considered normal for you? Or how do you check everything went fine for the compilation?
Anyway, I will start running the examples in order to learn about the usage of the code. And I guess any abnormality would appear there.
Many thanks,
Alexis
Dr Alexis Espinosa
26 Dick Perry Ave
Kensington  WA  6151
Australia
Tel  +61 xxxx xxxx
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180522/d23a498a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180522/d23a498a/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180522/d23a498a/attachment-0003.png>
