[Nek5000-users] ffx ffy ffz from current run
Mon May 21 07:53:17 CDT 2018
Dear Zhai,
I've also tested the procedure and did not have any difficulty.
What, exactly, is your target Reynolds number?
When you were running the fixed flow-rate case, what were
the settings for ffx,ffy,ffz in your usr file?
Best,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Monday, May 21, 2018 7:01:50 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] ffx ffy ffz from current run
Dear Paul,
After last request email (https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2018-March/005178.html), the ffz value of 0.01525 was obtained by 'grep volf logfile'. Then I used this value as ffz in usr file with changing para54 and 55 as 0 in the same time. The case was started from previous stop which is based on keeping flowrate.
After long time running (delt t*=200), the streamwise velocity was decreased compared with previous running . May I know what I can do to get the turbulence and velocity back?
Kind regards,
Zhai
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180521/9a6202d8/attachment.html>
