[Nek5000-users] hillp tutorial case, minimal updates are needed.
Tue May 15 00:48:43 CDT 2018
Dear all,
This is really not a major problem at all, although I believe is good to mention it in order to keep your documentation up-to-date as possible.
I was able to run the tutorial case hillp by reading the instructions in the documentation. Nevertheless, it seems that the tutorial notes have not been updated to the latest version of Nek5000, and there are small difference from what is written in the “code” blocks and within the general template-files copied from the installation. So, I suggest you to take a look into this small differences and update the tutorial accordingly.
Also, the setting for:
targetCFL
is missing in the tutorial notes. I suggest to add the suggested setting for this variable within the “code” block.
Many thanks,
Alexis
Dr Alexis Espinosa
Supercomputing Specialist
Pawsey Supercomputing Centre
26 Dick Perry Ave
Kensington  WA  6151
Australia
Tel  +61 xxxx xxxx
Email  alexis.espinosa at pawsey.org.au
Web  www.pawsey.org.au
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180515/175a248a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180515/175a248a/attachment-0001.png>
