[Nek5000-users] logfile
Fri Mar 30 08:32:17 CDT 2018
Please find the attached link with permissions enabled
 logfile
<https://drive.google.com/file/d/1co21p9SNAq_Vs0YQgSp9Y_PeAWvOfem3/view?usp=drive_web>
or try the link:
https://drive.google.com/file/d/1co21p9SNAq_Vs0YQgSp9Y_PeAWvOfem3/view?usp=sharing
On Fri, Mar 30, 2018 at 6:54 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Can you please change the permissions such that everyone with the link can
> read it. Thanks!
> -----Original message-----
> > From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> > Sent: Friday 30th March 2018 13:42
> > To: nek5000-users at lists.mcs.anl.gov
> > Subject: Re: [Nek5000-users] logfile
> > Please find the link for the logfile​
> >  logfile <https://drive.google.com/file/d/17OwfMBxok-
> h5Uy2QWtKGnQUYVBEiG5wC/view?usp=drive_web>​
> > On Fri, Mar 30, 2018 at 4:59 PM,  <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
> > Can you please attach your logfile?
> > > From:nek5000-users at lists.mcs.anl.gov <mailto:From%3Anek5000-users@
> lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov <mailto:
> > > Sent: Friday 30th March 2018 13:21
> > > To: nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.
> mcs.anl.gov>
> > > Thanks for the information.
> > > In my calculation, I am using a variable viscosity formulation. The
> > > viscosity depends on the temperature. As the run proceeds the initial
> > > residual for the TEMP gradually rises from 1E+03 until at around at
> > > the value 6E+07, the logfile shows an error for non-positive
> > > diffusivity. I have checked the temperature distribution which has no
> > > such value so as to make the diffusivity negative (or zero). Please
> > > indicate what I may be doing wrong.
> > > Thank you
> > > Swarandeep
> > > On Fri, Mar 30, 2018 at 3:30 PM,  <nek5000-users at lists.mcs.anl.gov
> > > >>Step   1520, t= 7.6000000E-02, DT= 5.0000000E-05, C=  0.072
> 5.3831E+03 3.5403E+00
> > > > timestep, time, dt, Courant Number, elapsed solver time, solver time
> of last time iteration
> > > >>1520  Hmholtz TEMP      12   3.8789E-11   4.5120E+07   1.0000E-10
> > > > timestep, solve type, iteration counter, final residual, initial
> residual, solver tolerance
> > > >> Sent: Friday 30th March 2018 11:52
> mcs.anl.gov>
> > > >> The following is my logfile entry (sample lines). The first line is
> > > >> understandable. What do the values in the third and following lines
> > > >> denote?
> 5.3831E+03
> > > >> 3.5403E+00
> > > >>              Solving for Hmholtz scalars
>  1.0000E-10
> > > >>        1520  Scalars done  7.6000E-02  8.3823E-02
> > > >>              Solving for fluid
> > > >>        1520  Helmh3 fluid      17   3.6594E-11   4.7524E-01
>  1.0000E-10
> > > >>        1520  U-PRES gmres     120   1.3494E-08   4.5675E-06
> > > >> 1.0000E-10   7.8799E-01   3.0171E+00
> > > >>        1520  Fluid done  7.6000E-02  3.3650E+00
> > > >> On Fri, Mar 30, 2018 at 3:05 PM,  <nek5000-users at lists.mcs.anl.gov
> > > >> > I am not sure what you are talking about?
> From%3Anek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov
> > > >> >> Sent: Friday 30th March 2018 10:30
> mcs.anl.gov>
> > > >> >> Subject: [Nek5000-users] logfile
> > > >> >> Hi Neks,
> > > >> >>      What are the entries in the logfile that is output from
> running
> > > >> >> the code.  Please let me know where the entries are determined
> in the
> > > >> >> code.
> > > >> >> Thanks
> > > >> >> Swarandeep
> > > >> >> _______________________________________________
> > > >> >> Nek5000-users mailing list
> > > >> >> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.
> mcs.anl.gov>
> > > >> >> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
> mcs.anl.gov>
> mcs.anl.gov>
> mcs.anl.gov>
> mcs.anl.gov>
> > Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180330/2e4868c5/attachment-0001.html>
