[Nek5000-users] logfile
Fri Mar 30 06:29:29 CDT 2018
Can you please attach your logfile?
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Friday 30th March 2018 13:21
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] logfile
> Thanks for the information.
> In my calculation, I am using a variable viscosity formulation. The
> viscosity depends on the temperature. As the run proceeds the initial
> residual for the TEMP gradually rises from 1E+03 until at around at
> the value 6E+07, the logfile shows an error for non-positive
> diffusivity. I have checked the temperature distribution which has no
> such value so as to make the diffusivity negative (or zero). Please
> indicate what I may be doing wrong.
> Thank you
> Swarandeep
> On Fri, Mar 30, 2018 at 3:30 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> >>Step   1520, t= 7.6000000E-02, DT= 5.0000000E-05, C=  0.072 5.3831E+03 3.5403E+00
> > timestep, time, dt, Courant Number, elapsed solver time, solver time of last time iteration
> >>1520  Hmholtz TEMP      12   3.8789E-11   4.5120E+07   1.0000E-10
> > timestep, solve type, iteration counter, final residual, initial residual, solver tolerance
> >> Sent: Friday 30th March 2018 11:52
> >> The following is my logfile entry (sample lines). The first line is
> >> understandable. What do the values in the third and following lines
> >> denote?
> >> 3.5403E+00
> >>              Solving for Hmholtz scalars
> >>        1520  Scalars done  7.6000E-02  8.3823E-02
> >>              Solving for fluid
> >>        1520  Helmh3 fluid      17   3.6594E-11   4.7524E-01   1.0000E-10
> >>        1520  U-PRES gmres     120   1.3494E-08   4.5675E-06
> >> 1.0000E-10   7.8799E-01   3.0171E+00
> >>        1520  Fluid done  7.6000E-02  3.3650E+00
> >> On Fri, Mar 30, 2018 at 3:05 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> >> > I am not sure what you are talking about?
> >> >> Sent: Friday 30th March 2018 10:30
> >> >> Subject: [Nek5000-users] logfile
> >> >> Hi Neks,
> >> >>      What are the entries in the logfile that is output from running
> >> >> the code.  Please let me know where the entries are determined in the
> >> >> code.
> >> >> Thanks
> >> >> Swarandeep
> >> >> _______________________________________________
> >> >> Nek5000-users mailing list
> >> >> Nek5000-users at lists.mcs.anl.gov
> >> >> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
