[Nek5000-users] Maximum number of history points using hpts()
Fri Mar 30 02:48:19 CDT 2018
Hi so lhis is equal to 359641 and I'm using 7 ranks.. However I can try
and increase that value (which I will try immediately).
Best,
Arnold
Le 29/03/2018 à 17:57, nek5000-users at lists.mcs.anl.gov a écrit :
> What's your lhis? How many MPI ranks are you using?
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Thursday 29th March 2018 17:54
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Maximum number of history points using hpts()
>> I'm executing 9 times nek5000 to call hpts (using different
>>        case.his files containing each 39960 points, using a shell script)
>>        because I need When I'm using 359640=9*39660 points
>> This works perfectly fine. However when I'm trying to use a
>>        single file in order to execute nek5000 once, it gives the
>>        following error following error when the number of points is equal
>>        to 359640 :
>>        dump history points
>>         reading history points
>>         found       359640  points
>>        APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault
>>        (signal 11)
>> I guess I'm encountering some memory problems..
>> Best regards,
>> Arnold
>> Le 29/03/2018 à 17:27,
>>        nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> a écrit :
>> What do you mean with doesn't work anymore. How does it manifest itself?
>> From:nek5000-users at lists.mcs.anl.gov <mailto:From:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov>
>> Sent: Thursday 29th March 2018 17:23
>> To: nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>
>> Hello Pierre,
>> In my case my case.his file contains 39960 points and lhis=39961,
>>        however when I increased the first value and the lhis variable
>>        accordingly it doesn't work anymore. Is there something I'm
>>        missing?
>> Best,
>> Arnold
>> Le 29/03/2018 à 16:30,
>>        nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov> a écrit :
>>      Hi
>>        Arnold,
>>        You can set it in the SIZE file:
>>        param(lhis=100) ! # of pts a proc reads from hpts.in
>>                                    ! Note: lhis*np > npoints in
>>        hpts.in
>>        best,
>>        Pierre
>>        On 2018-03-29 16:14, nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>        Hi Neks,
>>          I was wondering if there is any maximum number of history points
>>          one should put in the case.his file. If someone could help me
>>          regarding that topic, I haven't found any information yet.
>>          Thank you for your time,
>>          Best,
>>          Arnold
>>          _______________________________________________
>>          Nek5000-users mailing list
>>          Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov> <mailto:Nek5000-users at lists.mcs.anl.gov> <mailto:Nek5000-users at lists.mcs.anl.gov>
>>          https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users> <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users> <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>> Arnold Wakim
>>            Ph.D. Student
>>            Département Aérodynamique, Aéroélasticité, Acoustique
>>            INST
>>            Tél: +33 1 46 23 51 83
>>            ONERA - The French Aerospace Lab - Centre de Meudon
>>            8, rue des Vertugadins - 92190 MEUDON
>>            Nous suivre sur : www.onera.fr <http://www.onera.fr> <http://www.onera.fr> <http://www.onera.fr> | Twitter <http://www.twitter.com/@onera_fr> <http://www.twitter.com/@onera_fr> |  LinkedIn <http://www.linkedin.com/company/onera> <http://www.linkedin.com/company/onera> | Facebook <http://www.facebook.fr/thefrenchaerospacelab> <http://www.facebook.fr/thefrenchaerospacelab>
>>            Avertissement/disclaimer http://www.onera.fr/onera-en/emails-terms <http://www.onera.fr/onera-en/emails-terms> <http://www.onera.fr/onera-en/emails-terms> <http://www.onera.fr/onera-en/emails-terms>_______________________________________________
>> Arnold Wakim
>>            Ph.D. Student
>>            INST
>>            Nous suivre sur : www.onera.fr <http://www.onera.fr> | Twitter <http://www.twitter.com/@onera_fr> |  LinkedIn <http://www.linkedin.com/company/onera> | Facebook <http://www.facebook.fr/thefrenchaerospacelab>
>>            Avertissement/disclaimer http://www.onera.fr/onera-en/emails-terms <http://www.onera.fr/onera-en/emails-terms>_______________________________________________
*Arnold Wakim*
Ph.D. Student
INST
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180330/75a0037c/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180330/75a0037c/attachment-0001.gif>
