[Nek5000-users] 'comp_vort3' in 2D
Sat Mar 24 18:49:40 CDT 2018
Hello neks,
I am using 'comp_vort3' for a 2D flow, with a forcing in x direction,
call comp_vort3 (vort, w1, w2, vx, vy, vz)
call outpost (vort(1,1), vort(1,2), vort(1,3), pr, t, 'vrt')
In this case, the x and y component of vorticity should be trivial, and
only z component should remain. However I am getting a non-zero component
of x-component, vort(1,1) while vort(1,2) and vort(1,3) are zero.
However if I add a z-direction, comp_vort3 returns a non-zero value of
vort(1,3) and the x and y-components are zero, which should be the case.
So my question is, in 2D, does comp_vort3 return only one value which is in
vort(1,1)? The vorticity fields in both cases look sort of similar.
Saikat
Saikat Mukherjee,
PhD Student,
Paul Research Group - http://www.me.vt.edu/mpaul/
Engineering Science and Mechanics,
Virginia Tech.
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180324/ff4497f6/attachment.html>
