[Nek5000-users] Small random perturbations
Fri Mar 16 03:22:07 CDT 2018
Hello everyone
I have been troubled by the exactly same problem with Ali for the last two months with the turbulent channel case. When I increase elements, the flow is laminarized even though the Re is quite big (10000). I tried many different ways. Even added a constant random forcing, but the disturbance just disappear. (because the disturbance shape is not the same as that in linear stability theory, it is possible that the disturbance just decay. )
How I finally solve this problem is running a coarse mesh calculation first, and then interpolating the result to fine mesh. Then I got a sustaining turbulence and the result is quite satisfying. I hope this could solve Ali's problem.
However, I still cannot understand why increasing resolution would laminarize flow. hoping someone else could explain the problem.
Regards
Bien cordialement
Zhenrong JING
Doctorant (Doctor Candidate)
LHEEA
Ecole Centrale de Nantes
1 Rue de la Noë, 44321 Nantes, France
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180316/b3d63524/attachment.html>
