[Nek5000-users] Output files reading by python
Fri Mar 16 04:46:18 CDT 2018
Thank you very much..
I will give a try.
Regards
Sijo
----- Mail original -----
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Vendredi 16 Mars 2018 10:42:20
Objet: Re: [Nek5000-users] Output files reading by python
you start your simulation by loading an fld file, and then you write it
out directly as f file. This can be done by changing some of the
parameters, see the documentation.
On 2018-03-16 10:40, nek5000-users at lists.mcs.anl.gov wrote:
> sorry for silly questions..I am sorry I didn't get you
> load as fld?
> where?
> thanks
> silo
> Envoyé: Vendredi 16 Mars 2018 10:37:59
> load as fld, save as f*
> On 2018-03-16 10:36, nek5000-users at lists.mcs.anl.gov wrote:
>> I am sorry . I don't have much experience in that.
>>    Could you please tell me how can I convert?
>> Thanks
>> Envoyé: Vendredi 16 Mars 2018 10:33:00
>> I recommend to convert to f* format.
>> On 2018-03-16 10:29, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Arnold,
>>> I was trying to read .fld format.
>>> Is there any scripts I can read this?
>>> thank you
>>> sijo
>>> *De: *"nek5000-users" <nek5000-users at lists.mcs.anl.gov>
>>> *À: *"nek5000-users" <nek5000-users at lists.mcs.anl.gov>
>>> *Envoyé: *Vendredi 16 Mars 2018 09:47:46
>>> *Objet: *Re: [Nek5000-users] Output files reading by python
>>> Hi Sijo, what format are you trying to read?
>>> The files created by Nicolo (using python) are ONLY for *0.f0* files.
>>> Best regards,
>>> AW
>>> Le 15/03/2018 à 23:50, nek5000-users at lists.mcs.anl.gov a écrit :
>>>       Yes in fact I was using these codes. It was working for me with some cases and not with the file which I had attached. The header itself looks bit different. Could you please have look into that ?
>>>       Thank you
>>>       De: "nek5000-users"<nek5000-users at lists.mcs.anl.gov>
>>>       À: "nek5000-users"<nek5000-users at lists.mcs.anl.gov>
>>>       Envoyé: Jeudi 15 Mars 2018 23:43:46
>>>       Hi,
>>>       you can check the python library by Jacopo and Nicolo:
>>>       https://github.com/jcanton/pymech
>>>       There are also matlab routines around. Perhpas Adam can send you a link
>>>       to these.
>>>       Philipp
>>>       On 2018-03-15 23:42,nek5000-users at lists.mcs.anl.gov  wrote:
>>>           HI Neks,
>>>           I was trying to read the output files of NEK5000 using some python files
>>>           which are available in internet. But when I tried an old which is
>>>           attached in this email, it throws some error. But the same code was
>>>           working for other files. The attached file looks also bit different from
>>>           other files. I assume that the standard of construction for this file is
>>>           quite different from others. Could you please help me, to find a way to
>>>           read the NEK5000 output files by using python scripts? Or anyway to make
>>>           the standard output files?
>>>           Thanks
>>>           Sijo
>>>           _______________________________________________
>>>           Nek5000-users mailing list
>>>           Nek5000-users at lists.mcs.anl.gov
>>>           https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> *Arnold Wakim*
>>> Ph.D. Student
>>> Département Aérodynamique, Aéroélasticité, Acoustique
>>> INST
>>> Tél: +33 1 46 23 51 83
>>> ONERA - The French Aerospace Lab - Centre de Meudon
>>> 8, rue des Vertugadins - 92190 MEUDON
>>> Nous suivre sur : www.onera.fr <http://www.onera.fr> | Twitter
>>> <http://www.twitter.com/@onera_fr> | LinkedIn
>>> <http://www.linkedin.com/company/onera> | Facebook
>>> <http://www.facebook.fr/thefrenchaerospacelab>
>>> Avertissement/disclaimer http://www.onera.fr/onera-en/emails-terms
