[Nek5000-users] Output files reading by python
Fri Mar 16 04:40:15 CDT 2018
sorry for silly questions..I am sorry I didn't get you
load as fld?
where?
thanks
silo
----- Mail original -----
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Vendredi 16 Mars 2018 10:37:59
Objet: Re: [Nek5000-users] Output files reading by python
load as fld, save as f*
On 2018-03-16 10:36, nek5000-users at lists.mcs.anl.gov wrote:
> I am sorry . I don't have much experience in that.
>   Could you please tell me how can I convert?
> Thanks
> Envoyé: Vendredi 16 Mars 2018 10:33:00
> I recommend to convert to f* format.
> On 2018-03-16 10:29, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Arnold,
>> I was trying to read .fld format.
>> Is there any scripts I can read this?
>> thank you
>> sijo
>> *De: *"nek5000-users" <nek5000-users at lists.mcs.anl.gov>
>> *À: *"nek5000-users" <nek5000-users at lists.mcs.anl.gov>
>> *Envoyé: *Vendredi 16 Mars 2018 09:47:46
>> *Objet: *Re: [Nek5000-users] Output files reading by python
>> Hi Sijo, what format are you trying to read?
>> The files created by Nicolo (using python) are ONLY for *0.f0* files.
>> Best regards,
>> AW
>> Le 15/03/2018 à 23:50, nek5000-users at lists.mcs.anl.gov a écrit :
>>      Yes in fact I was using these codes. It was working for me with some cases and not with the file which I had attached. The header itself looks bit different. Could you please have look into that ?
>>      Thank you
>>      De: "nek5000-users"<nek5000-users at lists.mcs.anl.gov>
>>      À: "nek5000-users"<nek5000-users at lists.mcs.anl.gov>
>>      Envoyé: Jeudi 15 Mars 2018 23:43:46
>>      Hi,
>>      you can check the python library by Jacopo and Nicolo:
>>      https://github.com/jcanton/pymech
>>      There are also matlab routines around. Perhpas Adam can send you a link
>>      to these.
>>      Philipp
>>      On 2018-03-15 23:42,nek5000-users at lists.mcs.anl.gov  wrote:
>>          HI Neks,
>>          I was trying to read the output files of NEK5000 using some python files
>>          which are available in internet. But when I tried an old which is
>>          attached in this email, it throws some error. But the same code was
>>          working for other files. The attached file looks also bit different from
>>          other files. I assume that the standard of construction for this file is
>>          quite different from others. Could you please help me, to find a way to
>>          read the NEK5000 output files by using python scripts? Or anyway to make
>>          the standard output files?
>>          Thanks
>>          Sijo
>>          _______________________________________________
>>          Nek5000-users mailing list
>>          Nek5000-users at lists.mcs.anl.gov
>>          https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> *Arnold Wakim*
>> Ph.D. Student
>> Département Aérodynamique, Aéroélasticité, Acoustique
>> INST
>> Tél: +33 1 46 23 51 83
>> ONERA - The French Aerospace Lab - Centre de Meudon
>> 8, rue des Vertugadins - 92190 MEUDON
>> Nous suivre sur : www.onera.fr <http://www.onera.fr> | Twitter
>> <http://www.twitter.com/@onera_fr> | LinkedIn
>> <http://www.linkedin.com/company/onera> | Facebook
>> <http://www.facebook.fr/thefrenchaerospacelab>
>> Avertissement/disclaimer http://www.onera.fr/onera-en/emails-terms
