[Nek5000-users] Output files reading by python
Fri Mar 16 04:33:00 CDT 2018
I recommend to convert to f* format.
On 2018-03-16 10:29, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Arnold,
> I was trying to read .fld format.
> Is there any scripts I can read this?
> thank you
> sijo
> *De: *"nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> *À: *"nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> *Envoyé: *Vendredi 16 Mars 2018 09:47:46
> *Objet: *Re: [Nek5000-users] Output files reading by python
> Hi Sijo, what format are you trying to read?
> The files created by Nicolo (using python) are ONLY for *0.f0* files.
> Best regards,
> AW
> Le 15/03/2018 à 23:50, nek5000-users at lists.mcs.anl.gov a écrit :
>     Yes in fact I was using these codes. It was working for me with some cases and not with the file which I had attached. The header itself looks bit different. Could you please have look into that ?
>     Thank you
>     ----- Mail original -----
>     De: "nek5000-users"<nek5000-users at lists.mcs.anl.gov>
>     À: "nek5000-users"<nek5000-users at lists.mcs.anl.gov>
>     Envoyé: Jeudi 15 Mars 2018 23:43:46
>     Objet: Re: [Nek5000-users] Output files reading by python
>     Hi,
>     you can check the python library by Jacopo and Nicolo:
>     https://github.com/jcanton/pymech
>     There are also matlab routines around. Perhpas Adam can send you a link
>     to these.
>     Philipp
>     On 2018-03-15 23:42,nek5000-users at lists.mcs.anl.gov  wrote:
>         HI Neks,
>         I was trying to read the output files of NEK5000 using some python files
>         which are available in internet. But when I tried an old which is
>         attached in this email, it throws some error. But the same code was
>         working for other files. The attached file looks also bit different from
>         other files. I assume that the standard of construction for this file is
>         quite different from others. Could you please help me, to find a way to
>         read the NEK5000 output files by using python scripts? Or anyway to make
>         the standard output files?
>         Thanks
>         Sijo
>         _______________________________________________
>         Nek5000-users mailing list
>         Nek5000-users at lists.mcs.anl.gov
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> *Arnold Wakim*
> Ph.D. Student
> Département Aérodynamique, Aéroélasticité, Acoustique
> INST
> Tél: +33 1 46 23 51 83
> ONERA - The French Aerospace Lab - Centre de Meudon
> 8, rue des Vertugadins - 92190 MEUDON
> Nous suivre sur : www.onera.fr <http://www.onera.fr> | Twitter
> <http://www.twitter.com/@onera_fr> | LinkedIn
> <http://www.linkedin.com/company/onera> | Facebook
> <http://www.facebook.fr/thefrenchaerospacelab>
> Avertissement/disclaimer http://www.onera.fr/onera-en/emails-terms
