[Nek5000-users] comp_vort3, conj_ht
Sat Mar 10 05:30:28 CST 2018
I guess the routine is hardwired to to compute the curl of a field defined on the velocity mesh.
On 9 Mar 2018, at 15:11, "nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> " <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> > wrote:
Hello Nek team,
In conj_ht example, I compute curl using
  common /myvort/ b1(lx1,ly1,lz1,lelt,3),
  call comp_vort3(b1,work1,work2,t(1,1,1,1,1),
$     t(1,1,1,1,2),t(1,1,1,1,3))
b1 is being computed correctly in the fluid domain, but in the solid domain it is showing zero.
Can you please correct it to compute the curl in the solid domain?
Thanks in advance.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180310/21f11cee/attachment.html>
