[Nek5000-users] Measure resolution for simulations with low-diffusivity scalars
Fri Jun 29 10:44:36 CDT 2018
I want to evolve a scalar field \phi in my simulation with as low diffusivity (conductivity/(rhocp)) as possible.
I have performed simulations with sequentially reduced diffusivity D:
Simulation 1: D = 1*2.17*10^-5 m^2/s, polynomial order 7
Simulation 2: D = (1/4)*10^-5 m^2/s, polynomial order 7
Simulation 3: D = (1/4)*2.17*10^-5 m^2/s, polynomial order 11
Simulation 4: D = (1/8)*2.17*10^-5 m^2/s, polynomial order 11
Reducing the diffusivity, I keep the ratio D/dt constant, where dt is the time step.
At t = 0 \phi is bounded to 0 <= \phi <= 1, and it has no sources or sinks.
Currently, I check the resolution of the simulation after 25 s, by observing the range of \phi.
I find these values:
Simulation 1: -0.01 < \phi < 0.06
Simulation 2: -0.23 < \phi < 0.61
Simulation 3: -0.044 < \phi < 0.16
Simulation 4: -0.4 < \phi < 0.91
Indeed, the smaller the diffusivity D becomes, the worse resolution of \phi becomes.
Also, it seems as increasing the polynomial order improves the resolution of \phi.
However, the Courant numbers in my simulations are (on average):
Simulation 1: C = 0.31
Simulation 2: C = 0.06
Simulation 3: C = 0.14
Simulation 4: C = 0.06
That the Courant number goes down with increasing diffusivity is (I think) just  a consequence of reducing the time step (keeping the ratio D/dt constant).
According to the Courant number, I have really great resolution in Simulation 4, but according to the range of \phi I have not. Also, the Helmholtz solver seem to reach the tolerance in fewer iterations for low values of D.
Can somehow Nek output a measure of the resolution of a scalar field?
How can I improve the resolution at a low D/allow for lower D and keep a good resolution?
Best,
Johan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180629/d0154536/attachment.html>
