[Nek5000-users] torque calculation on airfoil
Fri Jun 22 18:20:05 CDT 2018
Hello Neks,
Finally I was successfully able to import mesh from ICEM to Nek5000 with periodic BCs. Now I have to set up a fluid structure interaction code in NEK5000.
The test case is called self sustained pitching of an airfoil. For that I had to calculate torque about the Elastic Axis(EA). I know that using toque_calc function I can calculate torque in x and y direction.
But I am bit confused with the input parameters for this function.
Here I show the code,
real x0(3)
save x0
data x0 /3*0/
x0(1) = 0.29016 ! X- Direction (Chord wise direction where chord length = 1.56)
x0(2) = 0.0 ! Y -Direction
x0(3) = 0.2 ! Z- Direction. (Span wise direction where total span width = 0.4)
n = nx1*ny1*nz1*nelv
if (istep.eq.0) call set_obj ! define objects for surface integrals
scale = 2. ! Cd = F/(.5 rho U^2 ) = 2*F
call torque_calc(scale,x0,.true.,.true.)
I just have to confirm that,
1) Here x0 is the Elastic Axis point right?
2) Am I correct with the Axis notations? (for example: x0(1) represents X direction?)
3)In fact, the simulation is 3D, but the thickness is just 0.4 and there is no motion in Z direction. So, to calculate torque for pitching do I have to give the value for x0(3)? If yes is that okay if I give the midpoint in z direction?
Thanks in advance
Sijo GEORGE
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180623/93d67dfc/attachment.html>
