[Nek5000-users] Stream function
Thu Jun 21 16:24:22 CDT 2018
Hi All,
I am reading in a Nek output file to postx, and would like to compute a streamfunction in postx and save that to a file format I can view in Visit.
After I select “DUMP vtk ALL”,  the resulting VTK file only contains a “VORTEX” and a “PRESSURE” variable when I plot it in VisIt.
I think I might be doing something wrong. Is there some other way this could be done in either Visit or ParaView?
Hannah
OUTPUT FILE
1  MAIN MENU
2  Set vtk sampling size
3  VIEW vtk S
4  DUMP vtk XYZ+S
5  DUMP vtk ALL
6  DUMP vtk surface
7  Animate vtk srf
8  Animate vtk multifield
9  Animate vtk vol
10  XYZ dump
11  XWD dump
12  pixel dump
13  set pixel window size
DUMP vtk ALL
This is iffmt_vtk: T
nelclip       1038      1038
ntot          9342     66432
call mapreg3d mx,nx         3         8
NVERT LEXICO:        1125           3        1038
THIS is nglb        4325           3        1038
this is nglb        4325        9342           3        1038
inside compress         9342        4325        4325
LTRUNC: string:           7
vtkfile
vtkfile
setwrk:   T  X  N                      VORTEX
ifnew_work: T T TOTAL PRESSURE                 4           4
T  quant: VORTEX
in vortex routine ifds, ialg F           2
  derivative:NO   (      64)
wkmax,delt:VORTEX                 9.69377422      -74.0063782       83.7001495
WORK - MAX,MIN:    9.6938       -74.006
wkmin: -7.4006E+01  4.0000E+01  1.0000E+00  0.0000E+00    43137
wkmax:  9.6938E+00  4.0048E+01  1.0000E+00  0.0000E+00    43139
Volume   of   domain:   1559.92
Integral of function: -0.411983E-01
POINT_DATA      4325
SCALARS VORTEX               float
LOOKUP_TABLE default
minmax: -6.005E+00  1.264E+00  VORTEX
setwrk:   F  M  N                      PRESSURE
ifnew_work: T F VORTEX                         4           4
T  quant: PRESSURE
  derivative:NO   (      64)
wkmax,delt:PRESSURE              0.223040715     -0.476195186      0.699235916
WORK - MAX,MIN:   0.22304      -0.47620
wkmin: -4.7620E-01  4.0000E+01  1.0000E+00  0.0000E+00    29561
wkmax:  2.2304E-01  4.1428E+01  0.0000E+00  0.0000E+00    26753
Integral of function:   105.272
SCALARS PRESSURE             float
minmax: -3.829E-01  2.046E-01  PRESSURE
1  MAIN MENU
3  VIEW vtk S
4  DUMP vtk XYZ+S
5  DUMP vtk ALL
6  DUMP vtk surface
7  Animate vtk srf
9  Animate vtk vol
10  XYZ dump
11  XWD dump
12  pixel dump
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180621/c64fe8c9/attachment.html>
