[Nek5000-users] In consistent periodic BC after prex
Mon Jun 18 11:25:43 CDT 2018
Hi Neks,
I did a mesh conversion from ICEM to NEK with ' ' (3 spaces) as boundary conditions instead of periodic. (It is a 3D naca profile). I tried n2to3 method for extrusion but I am not confident with that method since I already have a 3D mesh and my future works will be like that.
So my problem is, I am trying to set periodic boundary conditions on both sides of the naca wing. I use prex for that.
When I use prex for simple gemetries like cube and cylinder, the periodic conditions are set well.
But when I try on NACA the periodic BCs become in consistent and it runs a loop to check the consistency and not generating rea file anymore.
I commented some lines in source code (tools/prenek/bound.f) and tried to figure whats going on, then I generated an rea file and checked inside.
I saw that some elements are not set with Periodic bcs.
I understand that the loop helps to make the BC consitent.
But could you please tell me why it happens to NACA and not for simple gemoteries.
I am really stuck here..
Thank you
Sijo GEORGE
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180618/5ab7dccf/attachment.html>
