[Nek5000-users] genmap error after n3to2 and n2to3
Thu Jun 14 10:03:17 CDT 2018
hello Paul,
I tried your code n3to2 with slight modifications since it was throing some small errors. It is working fine now.
I converted 3D to 2D using n3to2.
And then I again converted to 3D by using n2to3.
Now there are two problems :
1) I could not make map file.
I was able to make before all conversions. And after n3to2 I tired to run genmap it thrown error like below:
ABORT: SELF-CHK 1 3 2 0
Try to tighten the mesh tolerance!
The I again I tried after n2to3. The same error.
2) problem with setting Periodic Conditions while using n2to3
NOTE: nlev < 3 not allowed with periodic bcs
nlev = 1
ABORT
Could you please help me to solve the above problems
Thank you
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180614/39a19ec5/attachment.html>
