[Nek5000-users] mshconvert.py elements between 100'000 and 1'000'000
Wed Jun 13 11:05:04 CDT 2018
I had to modify mshconvert.py to match the format required by Nek5000. I strongly encourage you to export your mesh in a exodus format and use the exo2nek script to convert to a Nek500 format. It is the recommended workflow for importing mesh and you will be able to get support from the Nek5000 developer and community.
Marco
On Jun 13, 2018, at 11:22 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hello Neks (espeacially Marco),
I am facing a genmap error like below :
 ERROR: error reading    1           1      33124
 aborting 530 in routine rdbdry.
I have elements in between 100'000 and 1'000'000. I have seen that there was an issue before same like this.
I know that it was the problem of mshconvert.py while converting the elements (elements in between 100'000 and 1'000'000).
Could you please tell me how can I solve this problem?
Thank you
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180613/4e9dd412/attachment.html>
