[Nek5000-users] Initial Condition & Recycling
Thu Jun 7 03:51:09 CDT 2018
Dear All,
In an attempt to simulate an established turbulent flow over a flat
plate with a recycling method for the inlet, it has to my attention that
a (1/7)th Power Law would be suitable as an initial condition. However
the solver divergences and I think I know why.
Here the layout of the recycling procedure :
1. call set_inflow_fpt in userchk
2. If it is the 1st call then call setp_inflow_fpt_setup
3. call rescale_fpt (which rescales the copied field to a user specified
mean velocity ubar)
4.In the rescale_fpt routine we call get_flux_and_area which gives the
flux and area of a face with cbc == 'v   ' so a user specified velocity
boundary condition.
4. a) As the initial condition is wrong once that routine sums the flux
on the boundary it returns zero in this case and the variable scale
which is divided by the latter returns infinity !
However I set the initial conditions as in many other examples, such as
the turbInflow. Would have an insight that could lead me to a solution ?
Please find attached the related files.
Sincerely,
Armand, ONERA - The French Aerospace Lab.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180607/89aba907/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180607/89aba907/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180607/89aba907/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180607/89aba907/attachment-0007.obj>
c
c     Include file to dimension static arrays
c     and to set some hardwired run-time parameters
c
      integer ldim,lx1,lxd,lx2,lx1m,lelg,lelt,lpmin,lpmax,ldimt
      integer lpelt,lbelt,toteq,lcvelt
      integer lelx,lely,lelz,mxprev,lgmres,lorder,lhis
      integer maxobj,lpert,nsessmax,lxo
      integer lfdm, ldimt_proj
      ! BASIC
      parameter (ldim=3)               ! domain dimension (2 or 3)
      parameter (lx1=8)                ! p-order (avoid uneven and values <6)
      parameter (lxd=8)                ! p-order for over-integration (dealiasing)
      parameter (lx2=lx1-0)            ! p-order for pressure (lx1 or lx1-2)
      parameter (lelg=1540)            ! max total number of elements
      parameter (lpmin=4)              ! min MPI ranks
      parameter (lpmax=64)             ! max MPI ranks
      parameter (ldimt=2)              ! max auxiliary fields (temperature + scalars)
      ! OPTIONAL
      parameter (ldimt_proj=1)         ! max auxiliary fields residual projection
      parameter (lhis=100)             ! max history points
      parameter (maxobj=4)             ! max number of objects
      parameter (lpert=1)              ! max perturbation modes
      parameter (toteq=1)              ! max number of conserved scalars in cmt
      parameter (nsessmax=1)           ! max sessions
      parameter (lxo=lx1)              ! max grid size on output (lxo>=lx1)
      parameter (lelx=16,lely=12,lelz=8) ! global tensor mesh dimensions
      parameter (mxprev=30,lgmres=20)  ! max dim of projection & Krylov space
      parameter (lorder=2)             ! max order in time
      parameter (lelt=lelg/lpmin + 2)  ! max number of local elements per MPI rank
      parameter (lx1m=1)               ! polynomial order mesh solver
      parameter (lbelt=1)              ! mhd
      parameter (lpelt=1)              ! linear stability
      parameter (lcvelt=1)             ! cvode
      parameter (lfdm=0)               ! == 1 for fast diagonalization method
      ! INTERNALS
      include 'SIZE.inc'
Type: application/vnd.previewsystems.box
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180607/89aba907/attachment-0001.box>
# nek parameter file
[GENERAL]
#startFrom = restart.fld
stopAt = endTime
endTime = 50
#numSteps = 0
dt = 0
timeStepper = bdf2
extrapolation = OIFS
variableDt = yes
targetCFL = 3.5
writeControl = timeStep #Was runTime
writeInterval = 1
userParam01 = 25.0    # start time collecting statistics default 100
userParam02 = 5.0     # writeInterval 1D statistics 20
#dealiasing = no
filtering = hpfrt # set to none in case of Smagorinski
filterWeight = 10
filterCutoffRatio = 0.9
[PROBLEMTYPE]
variableProperties = none # set to yes in case of Smagorinski
equation = incompNS
[PRESSURE]
preconditioner = semg_amg
residualTol = 1e-04
residualProj = yes
[VELOCITY]
residualTol = 1e-07
density = 1
viscosity = -840000
c-----------------------------------------------------------------------
c   CASE PARAMETERS:
c start time for averaging
#define tSTATSTART uparam(1)
c output frequency for statistics
#define tSTATFREQ  uparam(2)
c mesh dimensions
#define PI (4.*atan(1.))
#define NUMBER_ELEMENTS_X 16
#define NUMBER_ELEMENTS_Y 12
#define NUMBER_ELEMENTS_Z 8
      subroutine uservp (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      common /cdsmag/ ediff(lx1,ly1,lz1,lelv)
      ie     = gllel(ieg)
      udiff  = ediff(ix,iy,iz,ie)
      utrans = 1.
      return
      end
      subroutine userf  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ffx = 0.0 ! This value determined from fixed U_b=1 case.
      ffy = 0.0
      ffz = 0.0
      return
      end
      subroutine userq  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      qvol   = 0.0
      source = 0.0
      return
      end
      subroutine userchk
      include 'SIZE'
      include 'TOTAL'
      include 'ZPER'  ! for nelx,nely,nelz
      real x0(3)
      save x0
      integer icalld
      save    icalld
      data    icalld /0/
      real atime,timel
      save atime,timel
      integer ntdump
      save    ntdump
      common /plane/  uavg_pl(ly1*lely)
     $             ,  urms_pl(ly1*lely)
     $             ,  vrms_pl(ly1*lely)
     $             ,  wrms_pl(ly1*lely)
     $             ,  uvms_pl(ly1*lely)
     $             ,  yy(ly1*lely)
     $             ,  w1(ly1*lely),w2(ly1*lely)
      common /avg/    uavg(lx1,ly1,lz1,lelv)
     &             ,  urms(lx1,ly1,lz1,lelv)
     &             ,  vrms(lx1,ly1,lz1,lelv)
     &             ,  wrms(lx1,ly1,lz1,lelv)
     &             ,  uvms(lx1,ly1,lz1,lelv)
      common /ctorq/ dragx(0:maxobj),dragpx(0:maxobj),dragvx(0:maxobj)
     $             , dragy(0:maxobj),dragpy(0:maxobj),dragvy(0:maxobj)
     $             , dragz(0:maxobj),dragpz(0:maxobj),dragvz(0:maxobj)
c
     $             , torqx(0:maxobj),torqpx(0:maxobj),torqvx(0:maxobj)
     $             , torqy(0:maxobj),torqpy(0:maxobj),torqvy(0:maxobj)
     $             , torqz(0:maxobj),torqpz(0:maxobj),torqvz(0:maxobj)
c
     $             , dpdx_mean,dpdy_mean,dpdz_mean
     $             , dgtq(3,4)
      integer e
      logical ifverbose
      common /gaaa/    wo1(lx1,ly1,lz1,lelv)
     &              ,  wo2(lx1,ly1,lz1,lelv)
     &              ,  wo3(lx1,ly1,lz1,lelv)
      parameter (lt=lx1*ly1*lz1*lelt)
      common /myoutflow / d(lt),w1n(lt)
      real dx,dy,dz,ubar
      real tplus
      n=nx1*ny1*nz1*nelv
      ! do some checks
      if (istep.eq.0) then
         if(mod(nely,2).ne.0) then
           if(nid.eq.0) write(6,*) 'ABORT: nely has to be even!'
           call exitt
         endif
         if(nelx.gt.lelx .or. nely.gt.lely .or. nelz.gt.lelz) then
           if(nid.eq.0) write(6,*) 'ABORT: nel_xyz > lel_xyz!'
           call exitt
         endif
         call set_obj                   ! objects for surface integrals
         call rzero(x0,3)               ! torque w.r.t. x0
      endif
      ! Compute eddy viscosity using dynamic smagorinsky model
      if(ifuservp) then
        if(nid.eq.0) write(6,*) 'Calculating eddy visosity'
        do e=1,nelv
           call eddy_visc(ediff,e)
        enddo
        call copy(t,ediff,n)
      endif
      ub = glsc2(vx,bm1,n)/volvm1
      e2   = glsc3(vy,bm1,vy,n)+glsc3(vz,bm1,vz,n)
      e2   = e2/volvm1
      if(nid.eq.0) write(6,2) time,ub,e2
   2               format(1p3e13.4,' monitor')
      dx=5
      dy=0.
      dz=0.
      ubar = 1.0
      call set_inflow_fpt(dx,dy,dz,ubar)
c
c     Below is just for postprocessing ...
c
      if (time.lt.tSTATSTART) goto 999 ! don't start averaging
      nelx  = NUMBER_ELEMENTS_X
      nely  = NUMBER_ELEMENTS_Y
      nelz  = NUMBER_ELEMENTS_Z
      rho    = 1.
      dnu    = param(2)
      A_w    = XLEN * ZLEN
      if(ifoutfld) then
        if(ldimt.ge.2) call lambda2(t(1,1,1,1,2))
        if(ldimt.ge.5) call comp_vort3(t(1,1,1,1,3),wo1,wo2,vx,vy,vz)
      endif
      call torque_calc(1.0,x0,.false.,.false.) ! wall shear
      if(icalld.eq.0) then
        call rzero(uavg,n)
        call rzero(urms,n)
        call rzero(vrms,n)
        call rzero(wrms,n)
        call rzero(uvms,n)
        dragx_avg = 0
        atime = 0
        timel = time
        call planar_average_s(yy,ym1,w1,w2)
        icalld = 1
        ntdump = int(time/tSTATFREQ)
        if(nid.eq.0) write(6,*) 'Start collecting statistics ...'
      endif
      dtime = time - timel
      atime = atime + dtime
      if (atime.ne.0. .and. dtime.ne.0.) then
        beta      = dtime/atime
        alpha     = 1.-beta
        ifverbose = .false.
        call avg1(uavg,vx   ,alpha,beta,n,'uavg',ifverbose)
        call avg2(urms,vx   ,alpha,beta,n,'urms',ifverbose)
        call avg2(vrms,vy   ,alpha,beta,n,'vrms',ifverbose)
        call avg2(wrms,vz   ,alpha,beta,n,'wrms',ifverbose)
        call avg3(uvms,vx,vy,alpha,beta,n,'uvmm',ifverbose)
        dragx_avg = alpha*dragx_avg + beta*0.5*(dragx(1)+dragx(2))
        ! averaging over statistical homogeneous directions (r-t)
        call planar_average_s(uavg_pl,uavg,w1,w2)
        call planar_average_s(urms_pl,urms,w1,w2)
        call planar_average_s(vrms_pl,vrms,w1,w2)
        call planar_average_s(wrms_pl,wrms,w1,w2)
        call planar_average_s(uvms_pl,uvms,w1,w2)
        ! average over the domain height
        m = ny1*nely
        do i=1,ny1*nely
           uavg_pl(i) = 0.5 * (uavg_pl(i) + uavg_pl(m-i+1))
           urms_pl(i) = 0.5 * (urms_pl(i) + urms_pl(m-i+1))
           vrms_pl(i) = 0.5 * (vrms_pl(i) + vrms_pl(m-i+1))
           wrms_pl(i) = 0.5 * (wrms_pl(i) + wrms_pl(m-i+1))
        enddo
      endif
      ! write statistics to file
      if (nid.eq.0 .and. istep.gt.0 .and.
     &   time.gt.(ntdump+1)*tSTATFREQ) then
         tw     = dragx_avg/A_w
         u_tau  = sqrt(tw/rho)
         Re_tau = u_tau*DELTA/dnu
         tplus  = time * Re_tau * u_tau
         ntdump = ntdump + 1
         write(6,*) 'Dumping statistics ...', tplus, Re_tau
         open(unit=56,file='vel_fluc_prof.dat')
         write(56,'(A,1pe14.7)') '#time = ', time
         write(56,'(A)')
     &   '#  y     y+     uu     vv     ww     uv'
         open(unit=57,file='mean_prof.dat')
         write(57,'(A,1pe14.7)') '#time = ', time
         write(57,'(A)')
     &   '#  y     y+    Umean'
         m = ny1*nely
         do i=1,m
            write(56,3) yy(i)+1
     &                ,(yy(i)+1)*Re_tau
     &                , (urms_pl(i)-(uavg_pl(i))**2)/u_tau**2
     &                , vrms_pl(i)/u_tau**2
     &                , wrms_pl(i)/u_tau**2
     &                , uvms_pl(i)/u_tau**2
            write(57,3)  yy(i) + 1.
     &                , (yy(i)+1.)*Re_tau
     &                , uavg_pl(i)/u_tau
    3       format(1p15e17.9)
        enddo
        close(56)
        close(57)
      endif
      timel = time
 999  continue
      return
      end
      subroutine userbc (ix,iy,iz,iside,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      common /cvelbc/ uin(lx1,ly1,lz1,lelv)
     $              , vin(lx1,ly1,lz1,lelv)
     $              , win(lx1,ly1,lz1,lelv)
      integer e,f,eg
      e = gllel(eg)
      ux=uin(i,j,k,e)
      uy=vin(i,j,k,e)
      uz=win(i,j,k,e)
      temp=0.0
      return
      end
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer idum
      save    idum
      data    idum  / 999 /
c     1/7th power law velocity profile for an established boundary layer
      real Uinf = 8.4
      real nu = 1e-5
      real xin = 95.
      real ymax = 4.
      delta = 0.37*(nu/Uinf)**(1/5.)*(x+xin)**(4/5.)
      ybar = y/ymax
      ux = Uinf*(ybar/delta)**(1/7.)
      temp=0
      return
      end
      subroutine usrdat   ! This routine to modify element vertices
      include 'SIZE'      ! _before_ mesh is generated, which
      include 'TOTAL'     ! guarantees GLL mapping of mesh.
      return
      end
      subroutine usrdat2   ! This routine to modify mesh coordinates
      include 'SIZE'
      include 'TOTAL'
      return
      end
      subroutine usrdat3
      include 'SIZE'
      include 'TOTAL'
      return
      end
      subroutine set_obj  ! define objects for surface integrals
c
      include 'SIZE'
      include 'TOTAL'
c
      integer e,f
c
c     Define new objects
c
      nobj = 2			! for Periodic
      iobj = 0
      do ii=nhis+1,nhis+nobj
         iobj = iobj+1
         hcode(10,ii) = 'I'
         hcode( 1,ii) = 'F' ! 'F'
         hcode( 2,ii) = 'F' ! 'F'
         hcode( 3,ii) = 'F' ! 'F'
         lochis(1,ii) = iobj
      enddo
      nhis = nhis + nobj
c
      if (maxobj.lt.nobj) write(6,*) 'increase maxobj in SIZEu. rm *.o'
      if (maxobj.lt.nobj) call exitt
c
      nxyz = nx1*ny1*nz1
      do e=1,nelv
      do f=1,2*ndim
         if (cbc(f,e,1).eq.'W  ') then
            iobj = 0
            if (f.eq.1) iobj=1  ! lower wall
            if (f.eq.3) iobj=2  ! upper wall
            if (iobj.gt.0) then
               nmember(iobj) = nmember(iobj) + 1
               mem = nmember(iobj)
               ieg = lglel(e)
               object(iobj,mem,1) = ieg
               object(iobj,mem,2) = f
c              write(6,1) iobj,mem,f,ieg,e,nid,' OBJ'
    1          format(6i9,a4)
            endif
c
         endif
      enddo
      enddo
c     write(6,*) 'number',(nmember(k),k=1,4)
c
      return
      end
      subroutine comp_lij(lij,u,v,w,fu,fv,fw,fh,fht,e)
c
c     Compute Lij for dynamic Smagorinsky model:
c                    _   _      _______
c          L_ij  :=  u_i u_j  - u_i u_j
c
      include 'SIZE'
c
      integer e
c
      real lij(lx1*ly1*lz1,3*ldim-3)
      real u  (lx1*ly1*lz1,lelv)
      real v  (lx1*ly1*lz1,lelv)
      real w  (lx1*ly1*lz1,lelv)
      real fu (1) , fv (1) , fw (1)
     $   , fh (1) , fht(1)
      call tens3d1(fu,u(1,e),fh,fht,nx1,nx1)  ! fh x fh x fh x u
      call tens3d1(fv,v(1,e),fh,fht,nx1,nx1)
      call tens3d1(fw,w(1,e),fh,fht,nx1,nx1)
      n = nx1*ny1*nz1
      do i=1,n
         lij(i,1) = fu(i)*fu(i)
         lij(i,2) = fv(i)*fv(i)
         lij(i,3) = fw(i)*fw(i)
         lij(i,4) = fu(i)*fv(i)
         lij(i,5) = fv(i)*fw(i)
         lij(i,6) = fw(i)*fu(i)
      enddo
      call col3   (fu,u(1,e),u(1,e),n)    !  _______
      call tens3d1(fv,fu,fh,fht,nx1,nx1)  !  u_1 u_1
      call sub2   (lij(1,1),fv,n)
      call col3   (fu,v(1,e),v(1,e),n)    !  _______
      call tens3d1(fv,fu,fh,fht,nx1,nx1)  !  u_2 u_2
      call sub2   (lij(1,2),fv,n)
      call col3   (fu,w(1,e),w(1,e),n)    !  _______
      call tens3d1(fv,fu,fh,fht,nx1,nx1)  !  u_3 u_3
      call sub2   (lij(1,3),fv,n)
      call col3   (fu,u(1,e),v(1,e),n)    !  _______
      call tens3d1(fv,fu,fh,fht,nx1,nx1)  !  u_1 u_2
      call sub2   (lij(1,4),fv,n)
      call col3   (fu,v(1,e),w(1,e),n)    !  _______
      call tens3d1(fv,fu,fh,fht,nx1,nx1)   !  u_2 u_3
      call sub2   (lij(1,5),fv,n)
      call col3   (fu,w(1,e),u(1,e),n)    !  _______
      call tens3d1(fv,fu,fh,fht,nx1,nx1)  !  u_3 u_1
      call sub2   (lij(1,6),fv,n)
      return
      end
      subroutine comp_mij(mij,sij,dg2,fs,fi,fh,fht,nt,e)
c
c     Compute Mij for dynamic Smagorinsky model:
c
c                     2 _  ____     _______
c          M_ij  :=  a  S  S_ij  -  S  S_ij
c
      include 'SIZE'
c
      integer e
c
      real mij(lx1*ly1*lz1,3*ldim-3)
      real dg2(lx1*ly1*lz1,lelv)
      real fs (1) , fi (1) , fh (1) , fht(1)
      real magS(lx1*ly1*lz1)
      real sij (lx1*ly1*lz1*ldim*ldim)
      integer imap(6)
      data imap / 0,4,8,1,5,2 /
      n = nx1*ny1*nz1
      call mag_tensor_e(magS,sij)
      call cmult(magS,2.0,n)
c     Filter S
      call tens3d1(fs,magS,fh,fht,nx1,nx1)  ! fh x fh x fh x |S|
c     a2 is the test- to grid-filter ratio, squared
      a2 = nx1-1       ! nx1-1 is number of spaces in grid
      a2 = a2 /(nt-1)  ! nt-1 is number of spaces in filtered grid
      do k=1,6
         jj = n*imap(k) + 1
         call col3   (fi,magS,sij(jj),n)
         call tens3d1(mij(1,k),fi,fh,fht,nx1,nx1)  ! fh x fh x fh x (|S| S_ij)
         call tens3d1(fi,sij(jj),fh,fht,nx1,nx1)  ! fh x fh x fh x S_ij
         do i=1,n
            mij(i,k) = (a2**2 * fs(i)*fi(i) - mij(i,k))*dg2(i,e)
         enddo
      enddo
      return
      end
      subroutine eddy_visc(ediff,e)
c
c     Compute eddy viscosity using dynamic smagorinsky model
c
      include 'SIZE'
      include 'TOTAL'
      include 'ZPER'
      real ediff(nx1*ny1*nz1,nelv)
      integer e
      common /dynsmg/ sij (lx1*ly1*lz1,ldim,ldim)
     $              , mij (lx1*ly1*lz1,3*ldim-3)
     $              , lij (lx1*ly1*lz1,3*ldim-3)
     $              , dg2 (lx1*ly1*lz1,lelv)
     $              , num (lx1*ly1*lz1,lelv)
     $              , den (lx1*ly1*lz1,lelv)
     $              , snrm(lx1*ly1*lz1,lelv)
     $              , numy(ly1*lely),deny(ly1*lely),yy(ly1*lely)
      real sij,mij,lij,dg2,num,den,snrm,numy,deny,yy
      parameter(lxyz=lx1*ly1*lz1)
      common /xzmp0/ ur (lxyz) , us (lxyz) , ut (lxyz)
      real           vr (lxyz) , vs (lxyz) , vt (lxyz)
     $     ,         wr (lxyz) , ws (lxyz) , wt (lxyz)
      common /xzmp1/ w1(lx1*lelv),w2(lx1*lelv)
      !! NOTE CAREFUL USE OF EQUIVALENCE HERE !!
      equivalence (vr,lij(1,1)),(vs,lij(1,2)),(vt,lij(1,3))
     $          , (wr,lij(1,4)),(ws,lij(1,5)),(wt,lij(1,6))
      common /sgsflt/ fh(lx1*lx1),fht(lx1*lx1),diag(lx1)
      integer nt
      save    nt
      data    nt / -9 /
      ntot = nx1*ny1*nz1
      if (nt.lt.0) call
     $   set_ds_filt(fh,fht,nt,diag,nx1)! dyn. Smagorinsky filter
      call comp_gije(sij,vx(1,1,1,e),vy(1,1,1,e),vz(1,1,1,e),e)
      call comp_sije(sij)
      call mag_tensor_e(snrm(1,e),sij)
      call cmult(snrm(1,e),2.0,ntot)
      call set_grid_spacing(dg2)
      call comp_mij   (mij,sij,dg2,ur,us,fh,fht,nt,e)
      call comp_lij   (lij,vx,vy,vz,ur,us,ut,fh,fht,e)
c     Compute numerator (ur) & denominator (us) for Lilly contraction
      n = nx1*ny1*nz1
      do i=1,n
         ur(i) = mij(i,1)*lij(i,1)+mij(i,2)*lij(i,2)+mij(i,3)*lij(i,3)
     $      + 2*(mij(i,4)*lij(i,4)+mij(i,5)*lij(i,5)+mij(i,6)*lij(i,6))
         us(i) = mij(i,1)*mij(i,1)+mij(i,2)*mij(i,2)+mij(i,3)*mij(i,3)
     $      + 2*(mij(i,4)*mij(i,4)+mij(i,5)*mij(i,5)+mij(i,6)*mij(i,6))
      enddo
c     smoothing numerator and denominator in time
      call copy (vr,ur,nx1*nx1*nx1)
      call copy (vs,us,nx1*nx1*nx1)
      beta1 = 0.0                   ! Temporal averaging coefficients
      if (istep.gt.1) beta1 = 0.9   ! Retain 90 percent of past
      beta2 = 1. - beta1
      do i=1,n
         num (i,e) = beta1*num(i,e) + beta2*vr(i)
         den (i,e) = beta1*den(i,e) + beta2*vs(i)
      enddo
      if (e.eq.nelv) then  ! planar avg and define nu_tau
         call dsavg(num)   ! average across element boundaries
         call dsavg(den)
         call planar_average_s      (numy,num,w1,w2)
c        call wall_normal_average_s (numy,ny1,nely,w1,w2)
         call planar_fill_s         (num,numy)
         call planar_average_s      (deny,den,w1,w2)
c        call wall_normal_average_s (deny,ny1,nely,w1,w2)
         call planar_fill_s         (den,deny)
c - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
c DIAGNOSTICS ONLY
c         if (nid.eq.0.and.istep.eq.0) open(unit=55,file='z.z')
c         if (nid.eq.0.and.mod(istep,10).eq.0) write(55,1)
c    1    format(/)
c
c         ny = ny1*nely
c         do i=1,ny
c            cdyn = 0
c            if (deny(i).gt.0) cdyn = 0.5*numy(i)/deny(i)
c            cdyn0 = max(cdyn,0.)
c            if (nid.eq.0.and.mod(istep,10).eq.0) write(55,6)
c     $         istep,i,time,yy(i),cdyn0,cdyn,numy(i),deny(i)
c    6       format(i6,i4,1p6e12.4)
c         enddo
c DIAGNOSTICS ONLY
         ntot = nx1*ny1*nz1*nelv
         do i=1,ntot
            cdyn = 0
            if (den(i,1).gt.0) cdyn = 0.5*num(i,1)/den(i,1)
            cdyn = max(cdyn,0.)   ! AS ALTERNATIVE, could clip ediff
            ediff(i,1) = param(2)+cdyn*dg2(i,1)*snrm(i,1)
         enddo
      endif
c     if (e.eq.nelv) call outpost(num,den,snrm,den,ediff,'dif')
c     if (e.eq.nelv) call exitt
      return
      end
      subroutine set_ds_filt(fh,fht,nt,diag,nx) ! setup test filter
      INCLUDE 'SIZE'
      real fh(nx*nx),fht(nx*nx),diag(nx)
c Construct transfer function
      call rone(diag,nx)
c      diag(nx-0) = 0.01
c      diag(nx-1) = 0.10
c      diag(nx-2) = 0.50
c      diag(nx-3) = 0.90
c      diag(nx-4) = 0.99
c      nt = nx - 2
      diag(nx-0) = 0.05
      diag(nx-1) = 0.50
      diag(nx-2) = 0.95
      nt = nx - 1
      call build_1d_filt(fh,fht,diag,nx,nid)
      return
      end
      subroutine planar_average_r(ua,u,w1,w2)
c
c     Compute s-t planar average of quantity u()
c
      include 'SIZE'
      include 'GEOM'
      include 'PARALLEL'
      include 'WZ'
      include 'ZPER'
c
      real ua(nx1,lelx),u(nx1,ny1,nx1,nelv),w1(nx1,lelx),w2(nx1,lelx)
      integer e,eg,ex,ey,ez
c
      nx = nx1*nelx
      call rzero(ua,nx)
      call rzero(w1,nx)
c
      do e=1,nelt
c
         eg = lglel(e)
         call get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
c
         do i=1,nx1
         do k=1,nz1
         do j=1,ny1
            zz = (1.-zgm1(i,1))/2.  ! = 1 for i=1, = 0 for k=nx1
            aa = zz*area(j,k,4,e) + (1-zz)*area(j,k,2,e)  ! wgtd jacobian
            w1(i,ex) = w1(i,ex) + aa
            ua(i,ex) = ua(i,ex) + aa*u(i,j,k,e)
         enddo
         enddo
         enddo
      enddo
c
      call gop(ua,w2,'+  ',nx)
      call gop(w1,w2,'+  ',nx)
c
      do i=1,nx
         ua(i,1) = ua(i,1) / w1(i,1)   ! Normalize
      enddo
c
      return
      end
      subroutine planar_average_s(ua,u,w1,w2)
c
c     Compute r-t planar average of quantity u()
c
      include 'SIZE'
      include 'GEOM'
      include 'PARALLEL'
      include 'WZ'
      include 'ZPER'
c
      real ua(ny1,nely),u(nx1,ny1,nx1,nelv),w1(ny1,nely),w2(ny1,nely)
c
      ny = ny1*nely
      call rzero(ua,ny)
      call rzero(w1,ny)
c
      do e=1,nelt
         eg = lglel(e)
c
         do k=1,nz1
         do j=1,ny1
         do i=1,nx1
            zz = (1.-zgm1(j,2))/2.  ! = 1 for i=1, = 0 for k=nx1
            aa = zz*area(i,k,1,e) + (1-zz)*area(i,k,3,e)  ! wgtd jacobian
            w1(j,ey) = w1(j,ey) + aa
            ua(j,ey) = ua(j,ey) + aa*u(i,j,k,e)
         enddo
         enddo
         enddo
      enddo
c
      call gop(ua,w2,'+  ',ny)
      call gop(w1,w2,'+  ',ny)
c
      do i=1,ny
      enddo
      return
      end
      subroutine planar_fill_s(u,ua)
c
c     Fill array u with planar values from ua().
c     For tensor-product array of spectral elements
c
      include 'SIZE'
      include 'GEOM'
      include 'PARALLEL'
      include 'WZ'
      include 'ZPER'
      real u(nx1,ny1,nz1,nelv),ua(ly1,lely)
      melxyz = nelx*nely*nelz
      if (melxyz.ne.nelgt) then
         write(6,*) nid,' Error in planar_fill_s'
     $                 ,nelgt,melxyz,nelx,nely,nelz
         call exitt
      endif
      do e=1,nelt
         eg = lglel(e)
         do j=1,ny1
         do k=1,nz1
         do i=1,nx1
            u(i,j,k,e) = ua(j,ey)
         enddo
         enddo
         enddo
      enddo
      return
      end
      subroutine set_grid_spacing(dg2)
c
c     Compute D^2, the grid spacing used in the DS sgs model.
c
      include 'SIZE'
      include 'TOTAL'
      real dg2(nx1,ny1,nz1,nelv)
      gamma = 1.
      gamma = gamma/ndim
      n = nx1*ny1*nz1*nelv
      call rone(dg2,n)
      return               ! Comment this line for a non-trivial Delta defn
      do e=1,nelv
         do k=1,nz1
           km = max(1  ,k-1)
           kp = min(nz1,k+1)
           do j=1,ny1
             jm = max(1  ,j-1)
             jp = min(ny1,j+1)
             do i=1,nx1
               im = max(1  ,i-1)
               ip = min(nx1,i+1)
               di = (xm1(ip,j,k,e)-xm1(im,j,k,e))**2
     $            + (ym1(ip,j,k,e)-ym1(im,j,k,e))**2
     $            + (zm1(ip,j,k,e)-zm1(im,j,k,e))**2
               dj = (xm1(i,jp,k,e)-xm1(i,jm,k,e))**2
     $            + (ym1(i,jp,k,e)-ym1(i,jm,k,e))**2
     $            + (zm1(i,jp,k,e)-zm1(i,jm,k,e))**2
               dk = (xm1(i,j,kp,e)-xm1(i,j,km,e))**2
     $            + (ym1(i,j,kp,e)-ym1(i,j,km,e))**2
     $            + (zm1(i,j,kp,e)-zm1(i,j,km,e))**2
               di = di/(ip-im)
               dj = dj/(jp-jm)
               dk = dk/(kp-km)
               dg2(i,j,k,e) = (di*dj*dk)**gamma
             enddo
           enddo
         enddo
      enddo
      call dsavg(dg2)  ! average neighboring elements
      return
      end
      subroutine wall_normal_average_s(u,ny,nel,v,w)
      real u(ny,nel),w(1),v(1)
      integer e
      k=0
      do e=1,nel    ! get rid of duplicated (ny,e),(1,e+1) points
      do i=1,ny-1
         k=k+1
         w(k) = u(i,e)
      enddo
      enddo
      k=k+1
      w(k) = u(ny,nel)
      n=k
      npass = 2     ! Smooth
      alpha = 0.2
      do ipass=1,npass
         do k=2,n-1
            v(k) = (1.-alpha)*w(k) + 0.5*alpha*(w(k-1)+w(k+1))
         enddo
         do k=1,n
            w(k) = v(k)
         enddo
      enddo
      k=0
      do e=1,nel    ! restore duplicated (ny,e),(1,e+1) points
         do i=1,ny-1
            k=k+1
            u(i,e) = w(k)
         enddo
      enddo
      k=k+1
      u(ny,nel)=w(k)
      do e=1,nel-1    ! restore duplicated (ny,e),(1,e+1) points
         u(ny,e) = u(1,e+1)
      enddo
      return
      end
c  subroutines that follow are for fintpts based method
      subroutine field_copy_si(fieldout,fieldin,idlist,nptsi)
      include 'SIZE'
      include 'TOTAL'
      real    fieldin(1),fieldout(1)
      integer idlist(1)
      do i=1,nptsi
        idx = idlist(i)
        fieldout(idx) = fieldin(i)
      enddo
      return
      end
C--------------------------------------------------------------------------
      subroutine field_eval_si(fieldout,fieldstride,fieldin)
      include 'SIZE'
      include 'TOTAL'
      real fieldout(1),fieldin(1)
      integer fieldstride,nptsi
      parameter (lt=lelv*lx1*lz1)
      integer elid_si(lt),proc_si(lt),ptid(lt),rcode_si(lt)
      common /ptlist_int/ elid_si,proc_si,ptid,rcode_si,nptsi
      real    rst_si(lt*ldim)
      common /ptlist_real/ rst_si
      integer inth_si
      common / fpt_h_si/ inth_si
c     Used for fgslib_findpts_eval of various fields
      call fgslib_findpts_eval(inth_si,fieldout,fieldstride,
     &                     rcode_si,1,
     &                     proc_si,1,
     &                     elid_si,1,
     &                     rst_si,ndim,nptsi,
     &                     fieldin)
      return
      end
      subroutine rescale_inflow_fpt(ubar_in)  ! rescale inflow
      include 'SIZE'
      include 'TOTAL'
      integer icalld,e,eg,f
      save    icalld
      data    icalld /0/
      call get_flux_and_area(ubar,abar)
      ubar  = ubar/abar        ! Ubar
      scale = ubar_in/ubar     ! Scale factor
      if (nid.eq.0.and.(istep.le.100.or.mod(istep,100).eq.0))
     $  write(6,1) istep,time,scale,ubar,abar
    1   format(1i8,1p4e14.6,' rescale')
c     Rescale the flow to match ubar_in
      do e=1,nelv
      do f=1,2*ldim
        if (cbc(f,e,1).eq.'v  ') then
           call facind (kx1,kx2,ky1,ky2,kz1,kz2,nx1,ny1,nz1,f)
           do iz=kz1,kz2
           do iy=ky1,ky2
           do ix=kx1,kx2
              uin(ix,iy,iz,e) =  scale*uin(ix,iy,iz,e)
              vin(ix,iy,iz,e) =  scale*vin(ix,iy,iz,e)
              win(ix,iy,iz,e) =  scale*win(ix,iy,iz,e)
           enddo
           enddo
           enddo
        endif
      enddo
      enddo
      ifield = 1       ! Project into H1, just to be sure....
      call dsavg(uin)
      call dsavg(vin)
      if (ldim.eq.3) call dsavg(win)
      return
      end
      subroutine get_flux_and_area(vvflux,vvarea)
      include 'SIZE'
      include 'TOTAL'
      real vvflux,vvarea
      real work(lx1*ly1*lz1)
      integer e,f
      nxz   = nx1*nz1
      nface = 2*ndim
      vvflux = 0.
      vvarea = 0.
      do e=1,nelv
      do f=1,nface
            call surface_flux(dq,uin,vin,win,e,f,work)
            vvflux = vvflux + dq
            vvarea = vvarea + vlsum(area(1,1,f,e),nxz)
         endif
      enddo
      enddo
      vvflux = glsum(vvflux,1)
      vvarea = glsum(vvarea,1)
      vvflux = -vvflux !flux in is negative
      return
      end
      subroutine set_inflow_fpt_setup(dxx,dyy,dzz)   ! set up inflow BCs
      include 'SIZE'
      include 'TOTAL'
c
c setup recirculation boundary condition based on user supplied dx,dy,dz
c dx,dy,dz is the vector from the inflow where the user wants the velocity
c data to be interpolated from
c
      integer icalld,e,eg,i,f,nptsi
      save    icalld
      data    icalld /0/
      real dxx,dyy,dzz
      parameter (lt=lx1*lz1*lelv)
      real rst_si(lt*ldim),xyz_si(lt*ldim)
      real dist_si(lt),vals_si(lt)
      integer elid_si(lt), proc_si(lt),ptid(lt)
      integer rcode_si(lt)
      integer inth_si
      common /nekmpi/ nidd,npp,nekcomm,nekgroup,nekreal
ccc
c     Gather info for findpts
ccc
      nptsi = 0
      nxyz = nx1*ny1*nz1
      do e=1,nelv
      do f=1,2*ndim  !Identify the xyz of the points that are to be found
           do iz=kz1,kz2
           do iy=ky1,ky2
           do ix=kx1,kx2
            nptsi = nptsi+1
            xyz_si(ldim*(nptsi-1)+1) = xm1(ix,iy,iz,e) + dxx
            xyz_si(ldim*(nptsi-1)+2) = ym1(ix,iy,iz,e) + dyy
      if (ldim.eq.3) xyz_si(ldim*(nptsi-1)+ldim) = zm1(ix,iy,iz,e) + dzz
            ptid(nptsi) = (e-1)*nxyz+(iz-1)*lx1*ly1+(iy-1)*lx1+ix
           enddo
           enddo
           enddo
       endif
      enddo
      enddo
      mptsi=iglmax(nptsi,1)
      if (mptsi.gt.lt)
     $  call exitti('ERROR: increase lt in inflow_fpt routines.$',mptsi)
c     Setup findpts
      tol     = 1e-10
      npt_max = 256
      nxf     = 2*nx1 ! fine mesh for bb-test
      nyf     = 2*ny1
      nzf     = 2*nz1
      bb_t    = 0.1 ! relative size to expand bounding boxes by
      call fgslib_findpts_setup(inth_si,nekcomm,npp,ndim,
     &                   xm1,ym1,zm1,nx1,ny1,nz1,
     &                   nelt,nxf,nyf,nzf,bb_t,n,n,
     &                   npt_max,tol)
c     Call findpts to determine el,proc,rst of the xyzs determined above
      call fgslib_findpts(inth_si,rcode_si,1,
     &             proc_si,1,
     &             elid_si,1,
     &             rst_si,ndim,
     &             dist_si,1,
     &             xyz_si(1),ldim,
     &             xyz_si(2),ldim,
     &             xyz_si(3),ldim,nptsi)
      return
      end
      subroutine set_inflow_fpt(dxx,dyy,dzz,ubar)   ! set up inflow BCs
      include 'SIZE'
      include 'TOTAL'
c velocity data to be interpolated from
      integer icalld
      save    icalld
      data    icalld /0/
      real dxx,dyy,dzz
      integer elid_si(lt), proc_si(lt),ptid(lt),rcode_si(lt)
      integer inth_si
c     Gather info for findpts and set up inflow BC
      if (icalld.eq.0) call set_inflow_fpt_setup(dxx,dyy,dzz)
      icalld=1
c     Eval fields and copy to uvwin array
      call field_eval_si(vals_si,1,vx)
      call field_copy_si(uin,vals_si,ptid,nptsi)
      call field_eval_si(vals_si,1,vy)
      call field_copy_si(vin,vals_si,ptid,nptsi)
      if (ldim.eq.3) then
        call field_eval_si(vals_si,1,vz)
        call field_copy_si(win,vals_si,ptid,nptsi)
      endif
c     Rescale the flow so that ubar,vbar or wbar is ubar
      call rescale_inflow_fpt(ubar)
      return
      end
c automatically added by makenek
      subroutine usrsetvert(glo_num,nel,nx,ny,nz) ! to modify glo_num
      integer*8 glo_num(1)
      return
      end
