[Nek5000-users] Mesh with two blocks
Fri Jun 1 14:38:18 CDT 2018
Ok, thank you for your help. I will give it a try.
Marco
On Jun 1, 2018, at 3:34 PM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Marco,
The way I normally do this is as follows:
  1.  build a valid fluid mesh ( "f.rea" )
  2.  build a valid solid mesh ("s.rea")
  3.  run pretex and pick option "3"
  4.  Enter session name (say, "c" for "combined")
  5.  Enter fluid session name, f
  6.  Enter solid session name, s
Hopefully, it produces a valid "c.rea" file ready for conjugate heat transfer.
Let me know if that doesn't work for you.
Best,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>> on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
Sent: Friday, June 1, 2018 2:10:04 PM
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] Mesh with two blocks
Paul,
thank you again for your reply.
When I generated a mesh in Cubit that has two blocks and then run it with Nek5000 I get nelv = nelt. How does Nek5000 know that block 1 is the fluid mesh and block 2 is the solid mesh?
I think I missing a step in the setup of my problem. I wonder how the mesh used in conj_ht was generated?
Marco
On Jun 1, 2018, at 3:04 PM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Depends on which routine.  Suppose userbc:
      if (ifield.eq.1) then ! fluid field
      else   ! thermal field
      endif
Or... if in userchk:
      integer e
      do e=1,nelt
           if (e.le.nelv) then ! fluid + temperature
           else    !  solid==temperature only
           endif
     enddo
Local elements are sorted:  1...nelv is fluid
1...nelt is thermal
nelv is <= nelt
Paul
Sent: Friday, June 1, 2018 1:53:03 PM
Thank you for your replies.
I am actually interested in generating a mesh for a conjugate gradient solve. In the conj_ht example, the solid block is differentiated from the liquid block by testing the element index, i.e., ieg > nelgt. Assuming that I generate a mesh with two blocks that represent the fluid and solid regions, respectively, how do I access these blocks in the usr file?
Marco
> On Jun 1, 2018, at 2:35 PM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
> Why don't you use the sidesets to set your BC?
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
>> Sent: Friday 1st June 2018 20:06
>> Subject: [Nek5000-users] Mesh with two blocks
>> Hi,
>> I would like to get some insights on how Nek5000 deals with meshes that contains more than one block. I generated a 2-D mesh with Cubit and was able to convert it to a re2 format with exo2nek but I do not know how to differentiate each block in the usr file to set boundary conditions for instance.
>> I went through the examples and did not find anything relevant to my question. Does anybody have experience with multi-block mesh? What is the proper approach when dealing with multi-block meshes in Nek5000?
>> Thanks,
>> Marco
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180601/72f3616d/attachment-0001.html>
