[Nek5000-users] Planar average in z-direction problem (image updated)
Tue Jul 24 09:28:16 CDT 2018
Dear Hyunduk,
I see several issues with the code you have.
The first point is that your code will not work properly
in parallel, so you need to be careful about parallel treatment
of IO if you are running on more than one MPI rank.
Secondly, it's generally not a good idea to test for equality
with real numbers -- are you certain that the y values of
interest are 0.0000000 ? or are they potentially 1.e-7 (say).
Some of the mesh generation tools will have noise and your
zero values might not be exactly zero.
zgm1 is the position of the nodal points on the interval [-1,1]
in the reference element
area() is the surface area at the top and bottom of each
element.   (Here, we assume that "top" in z means also
top in r-s-t space for the canonical Omega-hat := [-1,1]^3.)
Thus, aa is a linear combination of the area at the top of
the given element and bottom of the given element.   This
way the surface integral can handle tapered elements
(but nothing more complex than that).
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Tuesday, July 24, 2018 1:34 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Planar average in z-direction problem (image updated)
Hi, Neks
I wonder why planar_average_z in navier5.f shows wrong result.
here I attached 2 images.
1, https://drive.google.com/file/d/1Kng9HZfQW-TGTFwmFcXzbrcvhRYrQSdc/view?usp=sharing
2. https://drive.google.com/file/d/1FN3i5mE6VSoPeehG5evjC33WrD3J4lB5/view?usp=sharing
First image shows the z-directional grids points from zm1
(I wrote a code to extract z coordinate at y = 0 as follows:
insnum = nid
insuni = insnum + 1000
WRITE(insnam,98) 'inst_field_', insnum
OPEN(unit=insuni,file=insnam
      insnum = nid
      Open(unit=insuni,file=insnam)
      do i = 1,n
      if (ym1(i,1,1,1).eq.0.0)then
      WRITE(insuni,5) xm1(i,1,1,1)
     %                  ,  zm1(i,1,1,1)
     %                  ,  vx(i,1,1,1)
     %                  ,  vy(i,1,1,1)
     %                  ,  vz(i,1,1,1)
     %                  ,  phig(i,1,1,1)
      endif
      enddo
      CLOSE(insuni)
Then, I can collect lots of field data from each processor and sort data with ascending order using matlab.
So, I got the result as 1st image.
But when I use plannar_average_z
I got the result as shown in 2nd image.
1. I really want to modify the problems, so could you give me your idea on this problem?
2. Additionally, could you explain 'zgm1' and 'area'?
I noticed that, planar_average_r or s ... in turbChannel case has also 'area' but, those case are used to calculate on different direction.
But they used same input parameters.
What I understand about area is, surface area of element.
But I thought that different direction needs different indexing
      subroutine planar_average_z(ua,u,w1,w2)
c
c     Compute r-s planar average of quantity u()
c
      include 'SIZE'
      include 'GEOM'
      include 'PARALLEL'
      include 'WZ'
      include 'ZPER'
c
      real ua(lz1,nelz),u(lx1*ly1,lz1,nelv),w1(lz1,nelz),w2(lz1,nelz)
      integer e,eg,ez
c
      melxy = nelx*nely
c
      nz = lz1*nelz
      call rzero(ua,nz)
      call rzero(w1,nz)
c
      do e=1,nelt
c
          eg = lglel(e)
c         ez = 1 + (eg-1)/melxy
         call get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
c
         do k=1,lz1
         do i=1,lx1*ly1
            zz = (1.-zgm1(k,3))/2.  ! = 1 for k=1, = 0 for k=lz1
            aa = zz*area(i,1,5,e) + (1-zz)*area(i,1,6,e)  ! wgtd jacobian
            w1(k,ez) = w1(k,ez) + aa
            ua(k,ez) = ua(k,ez) + aa*u(i,k,e)
         enddo
         enddo
      enddo
c
      call gop(ua,w2,'+  ',nz)
      call gop(w1,w2,'+  ',nz)
c
      do i=1,nz
         ua(i,1) = ua(i,1) / w1(i,1)   ! Normalize
      enddo
c
      return
      end
Hyunduk.
Hyunduk Seo (Mr.)
Integrated Ph.D. course, School of Mechanical Engineering, Pusan National University
Experimental Thermo-Fluids Mechanics and Energy Systems (ExTENsys) Laboratory
http://fluid.pusan.ac.kr<http://fluid.pusan.ac.kr/>
T.: +82-51-510-1536 M.: +82-10-2964-0994
[http://webmail.pusan.ac.kr/api/notify.php?home=MjAxODA3MjQxNTM0MTR8bmVrNTAwMC11c2Vyc0BsaXN0cy5tY3MuYW5sLmdvdnxoZHNlbzAxMjNAcHVzYW4uYWMua3I=]
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180724/31a6d3b7/attachment.html>
