[Nek5000-users] Dirichlet-Neumann BC
Mon Jul 23 07:16:46 CDT 2018
Indeed traction boundary conditions are suitable. However it is unclear
which NEKUSE variable I should set. From bdry.f lines 1101 to 1103 :
             V1(IX,IY,IZ) = TRN
             V2(IX,IY,IZ) = TR1
             V3(IX,IY,IZ) = TR2
it seems that I should set TRN, TR1 and TR2 for (shear horizontal local)
'shl' BC.
The end goal here is to compute a friction velocity locally for which
loglaw - velocity at the first grid cell is zero.
For now whether I set 'shl' or 'SYM' I get the same results.
Le 18/07/2018 à 11:07, nek5000-users at lists.mcs.anl.gov a écrit :
> Hi,
> there are so-called traction boundary conditions (or mixed
> traction-velocity boundary conditions), see the documentation
> https://nek5000.github.io/NekDoc/theory.html
> (it is in the section about passive scalars, which is perhaps not
> ideal). The conditions should work for both PnPn and PnPn-2, but for
> some cases you need the stress formulation. I am not sure whether Nek
> is properly catching all impossible (or unimplemented) combinations.
> There are some Nek examples that use these conditions, so you can get
> some guidance from there.
> Hope this helps,
> Philipp
> On 2018-07-18 09:38, nek5000-users at lists.mcs.anl.gov wrote:
>> Dear Neks,
>> I have been looking into the different boundary conditions available
>> by default in bdry.f. However, I haven't seen any mixed conditions. I
>> would like to impose a no slip condition and specify the shear stress
>> at the boundary. The boundary is flat and aligned with the mesh.
>> Moreover it seems that shear stress boundary conditions are
>> applicable only to the Pn-Pn-2 formulation. Is there a way I can
>> specify the wall normal streamwise velocity gradient u_y as well ?
>> Best regards,
>> Armand.
>> *Armand Shams*
>> Master Thesis Intern
>> Département aérodynamique, aéroélasticité, acoustique
>> MSAT
>> Tél: +33 6 99 51 15 84
>> ONERA - The French Aerospace Lab - Centre de Meudon
>> 8, rue des Vertugadins - 92190 MEUDON
>> Nous suivre sur : www.onera.fr <https://www.onera.fr> | Twitter
>> <http://www.twitter.com/@onera_fr> | LinkedIn
>> <http://www.linkedin.com/company/onera> | Facebook
>> <http://www.facebook.fr/thefrenchaerospacelab>
>> Avertissement/disclaimer https://www.onera.fr/en/emails-terms
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
*Armand Shams*
MSAT
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180723/930943a9/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180723/930943a9/attachment-0001.gif>
