[Nek5000-users] Run time error
Mon Jul 23 04:25:18 CDT 2018
Thank you very much. I found the problem and I hope it should work.
Thanks for the help.
----- Mail original -----
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Lundi 23 Juillet 2018 11:19:00
Objet: Re: [Nek5000-users] Run time error
well, you get a segfault somewhere at the end of step 5016 or beginning
of 5017. I guess you need to debug your code, first identify where it
happens and then find a solution. But this is not something that the
mailing list can help.
On 2018-07-23 11:16, nek5000-users at lists.mcs.anl.gov wrote:
> Here is the last 15 time steps,
> Step   5002, t= 2.5060730E-01, DT= 2.6334630E-05, C=   .499 2.9631E+03 6.4746E-01
>               Solving for fluid
>         5002  Helmh3 fluid       4   3.2301E-09   2.8687E-03   1.0000E-07
>   5002 reorthogo: 0
>         5002  U-PRES gmres       1   9.7902E-07   1.0848E-06   1.0000E-06   1.0687E-02   2.0345E-02
>   5002  DNORM, DIVEX 0.979017414251552405E-06 0.979017414244615416E-06
>         5002  Fluid done  2.5061E-01  1.0325E-01
>      5002  2.50607295376E-01  6.91348098900E-01  2.43521097680E-01  4.47827001220E-01      1dragx
>      5002  2.50607295376E-01  7.39003317407E-07  9.98073784120E-07 -2.59070466713E-07      1dragy
>      5002  2.50607295376E-01 -2.89434103178E-07 -2.61006442373E-07 -2.84276608050E-08      1dragz
>      5002  2.50607295376E-01  1.26466785801E-07  1.23449081749E-07  3.01770405268E-09      1torqx
>      5002  2.50607295376E-01  4.66210074735E-09 -2.18142386531E-08  2.64763394004E-08      1torqy
>      5002  2.50607295376E-01 -1.39245119998E-06 -1.37178097352E-06 -2.06702264562E-08      1torqz
> Step   5003, t= 2.5063363E-01, DT= 2.6334630E-05, C=   .499 2.9636E+03 5.0625E-01
>               Solving for fluid
>         5003  Helmh3 fluid       4   3.2284E-09   2.8685E-03   1.0000E-07
>   5003 reorthogo: 0
>         5003  U-PRES gmres       2   9.9844E-07   1.2476E-06   1.0000E-06   2.1245E-02   4.0459E-02
>   5003  DNORM, DIVEX 0.998438496961438229E-06 0.998438496995218115E-06
>         5003  Fluid done  2.5063E-01  1.2349E-01
>      5003  2.50633630006E-01  6.91343372331E-01  2.43530821430E-01  4.47812550901E-01      1dragx
>      5003  2.50633630006E-01  1.33883527191E-06  1.59788610149E-06 -2.59050829576E-07      1dragy
>      5003  2.50633630006E-01 -2.89455853305E-07 -2.61026965361E-07 -2.84288879440E-08      1dragz
>      5003  2.50633630006E-01  1.26408336357E-07  1.23391016237E-07  3.01732012020E-09      1torqx
>      5003  2.50633630006E-01  3.68027948823E-09 -2.27921145675E-08  2.64723940558E-08      1torqy
>      5003  2.50633630006E-01 -1.00290395946E-06 -9.82230311773E-07 -2.06736476910E-08      1torqz
> Step   5004, t= 2.5065996E-01, DT= 2.6334630E-05, C=   .499 2.9641E+03 5.2639E-01
>               Solving for fluid
>         5004  Helmh3 fluid       4   3.2288E-09   2.8683E-03   1.0000E-07
>   5004 reorthogo: 0
>         5004  U-PRES gmres       6   9.6173E-07   1.2811E-06   1.0000E-06   6.3583E-02   1.2089E-01
>   5004  DNORM, DIVEX 0.961733547539616817E-06 0.961733547511125381E-06
>         5004  Fluid done  2.5066E-01  2.0408E-01
>      5004  2.50659964636E-01  6.91338822904E-01  2.43540719422E-01  4.47798103482E-01      1dragx
>      5004  2.50659964636E-01  1.24874530961E-06  1.50777140270E-06 -2.59026093090E-07      1dragy
>      5004  2.50659964636E-01 -2.89465334698E-07 -2.61035223976E-07 -2.84301107230E-08      1dragz
>      5004  2.50659964636E-01  1.26265232830E-07  1.23248343597E-07  3.01688923232E-09      1torqx
>      5004  2.50659964636E-01  3.78573331524E-09 -2.26826739824E-08  2.64684072976E-08      1torqy
>      5004  2.50659964636E-01 -1.06339152264E-06 -1.04271435718E-06 -2.06771654598E-08      1torqz
> Step   5005, time= 2.50686E-01, DT=  2.633E-05
>               Solving for fluid
>         5005  Helmh3 fluid       4   3.2297E-09   2.8681E-03   1.0000E-07
>   5005 reorthogo: 0
>         5005  U-PRES gmres       1   9.9687E-07   1.3440E-06   1.0000E-06   1.0692E-02   2.0364E-02
>   5005  DNORM, DIVEX 0.996871725480759347E-06 0.996871725467780684E-06
>         5005  Fluid done  2.5069E-01  1.0281E-01
>      5005  2.50686299266E-01  6.91334194687E-01  2.43550535727E-01  4.47783658960E-01      1dragx
>      5005  2.50686299266E-01  1.09616851227E-06  1.35517473326E-06 -2.59006220992E-07      1dragy
>      5005  2.50686299266E-01 -2.89485215237E-07 -2.61053885728E-07 -2.84313295093E-08      1dragz
>      5005  2.50686299266E-01  1.26237500989E-07  1.23221079188E-07  3.01642180084E-09      1torqx
>      5005  2.50686299266E-01  3.39617827483E-09 -2.30681746374E-08  2.64643529123E-08      1torqy
>      5005  2.50686299266E-01 -1.14135276097E-06 -1.12067128456E-06 -2.06814764025E-08      1torqz
> Step   5006, time= 2.50713E-01, DT=  2.633E-05
>               Solving for fluid
>         5006  Helmh3 fluid       4   3.2410E-09   2.8679E-03   1.0000E-07
>   5006 reorthogo: 0
>         5006  U-PRES gmres       5   8.8161E-07   2.1599E-06   1.0000E-06   5.2977E-02   1.0074E-01
>   5006  DNORM, DIVEX 0.881613814330421712E-06 0.881613814311075056E-06
>         5006  Fluid done  2.5071E-01  1.8287E-01
>      5006  2.50712633896E-01  6.91329604485E-01  2.43560387135E-01  4.47769217350E-01      1dragx
>      5006  2.50712633896E-01  1.43777322353E-06  1.69676731276E-06 -2.58994089237E-07      1dragy
>      5006  2.50712633896E-01 -2.89383022126E-07 -2.60950472113E-07 -2.84325500128E-08      1dragz
>      5006  2.50712633896E-01  1.27224824060E-07  1.24208987648E-07  3.01583641282E-09      1torqx
>      5006  2.50712633896E-01  4.44760336876E-09 -2.20126903424E-08  2.64602937112E-08      1torqy
>      5006  2.50712633896E-01 -9.84677597850E-07 -9.63990647078E-07 -2.06869507719E-08      1torqz
> Step   5007, time= 2.50739E-01, DT=  2.633E-05
>               Solving for fluid
>         5007  Helmh3 fluid       4   3.2591E-09   2.8677E-03   1.0000E-07
>   5007 reorthogo: 0
>         5007  U-PRES gmres      18   9.5587E-07   2.2352E-06   1.0000E-06   1.9039E-01   3.6388E-01
>   5007  DNORM, DIVEX 0.955873119537653350E-06 0.955873119540012972E-06
>         5007  Fluid done  2.5074E-01  4.4597E-01
>      5007  2.50738968526E-01  6.91324862597E-01  2.43570083958E-01  4.47754778640E-01      1dragx
>      5007  2.50738968526E-01  1.20307297002E-06  1.46204641771E-06 -2.58973447692E-07      1dragy
>      5007  2.50738968526E-01 -2.89417069365E-07 -2.60983294754E-07 -2.84337746105E-08      1dragz
>      5007  2.50738968526E-01  1.26831695982E-07  1.23816089695E-07  3.01560628701E-09      1torqx
>      5007  2.50738968526E-01  5.02139157632E-09 -2.14350565571E-08  2.64564481335E-08      1torqy
>      5007  2.50738968526E-01 -7.82904411358E-07 -7.62214464704E-07 -2.06899466533E-08      1torqz
> Step   5008, time= 2.50765E-01, DT=  2.633E-05
>               Solving for fluid
>         5008  Helmh3 fluid       4   3.2323E-09   2.8676E-03   1.0000E-07
>   5008 reorthogo: 0
>         5008  U-PRES gmres      20   9.0835E-07   2.3092E-06   1.0000E-06   2.1137E-01   4.0465E-01
>   5008  DNORM, DIVEX 0.908352025925184963E-06 0.908352025900079859E-06
>         5008  Fluid done  2.5077E-01  4.8687E-01
>      5008  2.50765303155E-01  6.91321406040E-01  2.43581063104E-01  4.47740342936E-01      1dragx
>      5008  2.50765303155E-01  2.74890528450E-06  3.00786518867E-06 -2.58959904170E-07      1dragy
>      5008  2.50765303155E-01 -2.89468785686E-07 -2.61033794512E-07 -2.84349911742E-08      1dragz
>      5008  2.50765303155E-01  1.26559461360E-07  1.23544367051E-07  3.01509430869E-09      1torqx
>      5008  2.50765303155E-01  3.49653887985E-09 -2.29559476187E-08  2.64524864985E-08      1torqy
>      5008  2.50765303155E-01 -7.50639979415E-07 -7.29944028055E-07 -2.06959513604E-08      1torqz
> Step   5009, time= 2.50792E-01, DT=  2.633E-05
>               Solving for fluid
>         5009  Helmh3 fluid       4   3.2421E-09   2.8674E-03   1.0000E-07
>   5009 reorthogo: 0
>         5009  U-PRES gmres      11   9.8214E-07   1.8725E-06   1.0000E-06   1.1646E-01   2.2180E-01
>   5009  DNORM, DIVEX 0.982139696736965556E-06 0.982139696702795612E-06
>         5009  Fluid done  2.5079E-01  3.0396E-01
>      5009  2.50791637785E-01  6.91315353362E-01  2.43589443294E-01  4.47725910069E-01      1dragx
>      5009  2.50791637785E-01  2.33682354097E-07  4.92616702902E-07 -2.58934348805E-07      1dragy
>      5009  2.50791637785E-01 -2.89487372587E-07 -2.61051167514E-07 -2.84362050730E-08      1dragz
>      5009  2.50791637785E-01  1.26715143423E-07  1.23700456898E-07  3.01468652550E-09      1torqx
>      5009  2.50791637785E-01  4.22547531068E-09 -2.22232504981E-08  2.64487258088E-08      1torqy
>      5009  2.50791637785E-01 -1.15647147333E-06 -1.13577307601E-06 -2.06983973201E-08      1torqz
> Step   5010, time= 2.50818E-01, DT=  2.633E-05
>               Solving for fluid
>         5010  Helmh3 fluid       4   3.2557E-09   2.8672E-03   1.0000E-07
>   5010 reorthogo: 0
>         5010  U-PRES gmres      11   9.7871E-07   1.4643E-06   1.0000E-06   1.1647E-01   2.2184E-01
>   5010  DNORM, DIVEX 0.978713374125623103E-06 0.978713374145168176E-06
>         5010  Fluid done  2.5082E-01  3.0435E-01
>      5010  2.50817972415E-01  6.91311580633E-01  2.43600100518E-01  4.47711480115E-01      1dragx
>      5010  2.50817972415E-01  1.59900014887E-07  4.18822790393E-07 -2.58922775507E-07      1dragy
>      5010  2.50817972415E-01 -2.89375448630E-07 -2.60938030333E-07 -2.84374182969E-08      1dragz
>      5010  2.50817972415E-01  1.27146994632E-07  1.24132866323E-07  3.01412830971E-09      1torqx
>      5010  2.50817972415E-01  3.86222016209E-09 -2.25823729936E-08  2.64445931557E-08      1torqy
>      5010  2.50817972415E-01 -1.75555627025E-06 -1.73485211374E-06 -2.07041565045E-08      1torqz
> Step   5011, time= 2.50844E-01, DT=  2.633E-05
>               Solving for fluid
>         5011  Helmh3 fluid       4   3.2445E-09   2.8670E-03   1.0000E-07
>   5011 reorthogo: 0
>         5011  U-PRES gmres       3   9.8584E-07   1.4800E-06   1.0000E-06   3.1853E-02   6.0543E-02
>   5011  DNORM, DIVEX 0.985840182003174908E-06 0.985840181989730166E-06
>         5011  Fluid done  2.5084E-01  1.4313E-01
>      5011  2.50844307045E-01  6.91307006675E-01  2.43609953588E-01  4.47697053087E-01      1dragx
>      5011  2.50844307045E-01  1.19376086041E-06  1.45267214241E-06 -2.58911282002E-07      1dragy
>      5011  2.50844307045E-01 -2.89518324212E-07 -2.61079698806E-07 -2.84386254057E-08      1dragz
>      5011  2.50844307045E-01  1.26538004874E-07  1.23524339762E-07  3.01366511130E-09      1torqx
>      5011  2.50844307045E-01  3.50102159475E-09 -2.29395957657E-08  2.64406173605E-08      1torqy
>      5011  2.50844307045E-01 -1.15532190933E-06 -1.13461210583E-06 -2.07098035033E-08      1torqz
> Step   5012, time= 2.50871E-01, DT=  2.633E-05
>               Solving for fluid
>         5012  Helmh3 fluid       4   3.2319E-09   2.8668E-03   1.0000E-07
>   5012 reorthogo: 0
>         5012  U-PRES gmres       5   9.5655E-07   1.5593E-06   1.0000E-06   5.3007E-02   1.0077E-01
>   5012  DNORM, DIVEX 0.956545576069178046E-06 0.956545576089094120E-06
>         5012  Fluid done  2.5087E-01  1.8317E-01
>      5012  2.50870641675E-01  6.91302353472E-01  2.43619724517E-01  4.47682628955E-01      1dragx
>      5012  2.50870641675E-01  9.11226385968E-07  1.17011932510E-06 -2.58892939132E-07      1dragy
>      5012  2.50870641675E-01 -2.89432479322E-07 -2.60992645110E-07 -2.84398342115E-08      1dragz
>      5012  2.50870641675E-01  1.27073588160E-07  1.24060305180E-07  3.01328297995E-09      1torqx
>      5012  2.50870641675E-01  4.82584823477E-09 -2.16110082294E-08  2.64368564641E-08      1torqy
>      5012  2.50870641675E-01 -1.17588004419E-06 -1.15516521543E-06 -2.07148287560E-08      1torqz
> Step   5013, time= 2.50897E-01, DT=  2.633E-05
>               Solving for fluid
>         5013  Helmh3 fluid       4   3.2287E-09   2.8666E-03   1.0000E-07
>   5013 reorthogo: 0
>         5013  U-PRES gmres       2   9.5713E-07   1.2499E-06   1.0000E-06   2.1281E-02   4.0455E-02
>   5013  DNORM, DIVEX 0.957134034958327482E-06 0.957134034942669443E-06
>         5013  Fluid done  2.5090E-01  1.2291E-01
>      5013  2.50896976305E-01  6.91297902394E-01  2.43629694642E-01  4.47668207752E-01      1dragx
>      5013  2.50896976305E-01  6.14485394545E-07  8.73364124021E-07 -2.58878729476E-07      1dragy
>      5013  2.50896976305E-01 -2.89427209756E-07 -2.60986168111E-07 -2.84410416450E-08      1dragz
>      5013  2.50896976305E-01  1.27234413257E-07  1.24221620967E-07  3.01279228989E-09      1torqx
>      5013  2.50896976305E-01  4.31696301276E-09 -2.21160739899E-08  2.64330370026E-08      1torqy
>      5013  2.50896976305E-01 -1.42260629409E-06 -1.40188632877E-06 -2.07199653204E-08      1torqz
> Step   5014, time= 2.50923E-01, DT=  2.633E-05
>               Solving for fluid
>         5014  Helmh3 fluid       4   3.2263E-09   2.8664E-03   1.0000E-07
>   5014 reorthogo: 0
>         5014  U-PRES gmres       8   9.8677E-07   1.7248E-06   1.0000E-06   8.4772E-02   1.6120E-01
>   5014  DNORM, DIVEX 0.986772488382639047E-06 0.986772488403645888E-06
>         5014  Fluid done  2.5092E-01  2.4381E-01
>      5014  2.50923310934E-01  6.91293384013E-01  2.43639594562E-01  4.47653789451E-01      1dragx
>      5014  2.50923310934E-01  1.72936300045E-06  1.98822152750E-06 -2.58858527045E-07      1dragy
>      5014  2.50923310934E-01 -2.89481745085E-07 -2.61039500236E-07 -2.84422448489E-08      1dragz
>      5014  2.50923310934E-01  1.27107116717E-07  1.24094741942E-07  3.01237477520E-09      1torqx
>      5014  2.50923310934E-01  3.69583275881E-09 -2.27333237863E-08  2.64291565451E-08      1torqy
>      5014  2.50923310934E-01 -8.03349762879E-07 -7.82624357654E-07 -2.07254052255E-08      1torqz
> Step   5015, time= 2.50950E-01, DT=  2.633E-05
>               Solving for fluid
>         5015  Helmh3 fluid       4   3.2296E-09   2.8662E-03   1.0000E-07
>   5015 reorthogo: 0
>         5015  U-PRES gmres       6   9.0937E-07   1.6936E-06   1.0000E-06   6.3624E-02   1.2093E-01
>   5015  DNORM, DIVEX 0.909368958162372379E-06 0.909368958244082366E-06
>         5015  Fluid done  2.5095E-01  2.0366E-01
>      5015  2.50949645564E-01  6.91288889659E-01  2.43649515583E-01  4.47639374076E-01      1dragx
>      5015  2.50949645564E-01  2.90375481535E-06  3.16258818400E-06 -2.58833368651E-07      1dragy
>      5015  2.50949645564E-01 -2.89416582294E-07 -2.60973134708E-07 -2.84434475857E-08      1dragz
>      5015  2.50949645564E-01  1.27171125092E-07  1.24159210559E-07  3.01191453351E-09      1torqx
>      5015  2.50949645564E-01  3.80951637878E-09 -2.26155828231E-08  2.64250992019E-08      1torqy
>      5015  2.50949645564E-01 -7.71080501129E-08 -5.63790769972E-08 -2.07289731157E-08      1torqz
> Step   5016, time= 2.50976E-01, DT=  2.633E-05
>               Solving for fluid
>         5016  Helmh3 fluid       4   3.2378E-09   2.8660E-03   1.0000E-07
>   5016 reorthogo: 0
>         5016  U-PRES gmres       2   8.5015E-07   1.3656E-06   1.0000E-06   2.1316E-02   4.0472E-02
>   5016  DNORM, DIVEX 0.850149772194823341E-06 0.850149772234970797E-06
>         5016  Fluid done  2.5098E-01  1.2322E-01
>      5016  2.50975980194E-01  6.91284214594E-01  2.43659253020E-01  4.47624961574E-01      1dragx
>      5016  2.50975980194E-01  1.87017133482E-06  2.12898116805E-06 -2.58809833233E-07      1dragy
>      5016  2.50975980194E-01 -2.89458661275E-07 -2.61014009813E-07 -2.84446514627E-08      1dragz
>      5016  2.50975980194E-01  1.27081549294E-07  1.24070042436E-07  3.01150685798E-09      1torqx
>      5016  2.50975980194E-01  2.90577561646E-09 -2.35150990040E-08  2.64208746205E-08      1torqy
>      5016  2.50975980194E-01 -7.33394593524E-07 -7.12661120859E-07 -2.07334726643E-08      1torqz
> 2018-07-22 09:30:52.570 (WARN ) [0xffef6aa91b0] :497945:ibm.runjob.client.Job: terminated by signal 11
> 2018-07-22 09:30:52.570 (WARN ) [0xffef6aa91b0] :497945:ibm.runjob.client.Job: abnormal termination by signal 11 from rank 1040
> Envoyé: Lundi 23 Juillet 2018 10:58:37
> can you perhaps post the last 20 or so lines of your output?
> This appears more like a problem of your system. Did you check potential
> standard error output?
> On 2018-07-23 10:56, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks,
>> I am facing an error while running the simulation which I never had before.
>> after 5001 time step the CFL number disappears and it gives an error
>> stops running.
>> (It is not CFL blowing. I mean if CFL blows it will show something like
>> CFL : ******* right? In my case it is not like this. The CFL dis appears
>> it is not even showing the CFL letters. ) Also it saves my output files
>> unto there.
>> Any one had the same problem before?
>> Thank you
>> Sijo
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
