[Nek5000-users] Run time error
Mon Jul 23 03:58:37 CDT 2018
can you perhaps post the last 20 or so lines of your output?
This appears more like a problem of your system. Did you check potential
standard error output?
On 2018-07-23 10:56, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> I am facing an error while running the simulation which I never had before.
> after 5001 time step the CFL number disappears and it gives an error
> stops running.
> (It is not CFL blowing. I mean if CFL blows it will show something like
> CFL : ******* right? In my case it is not like this. The CFL dis appears
> it is not even showing the CFL letters. ) Also it saves my output files
> unto there.
> Any one had the same problem before?
> Thank you
> Sijo
> Nek5000-users mailing list
