[Nek5000-users] Stream function
Thu Jul 12 13:47:10 CDT 2018
Hi Philipp,
Thanks very much for the userchk routine.
I have been testing this with the Blasius example in Nek. I am hoping to implement this with my geometry (a 2-D backward facing step with the Blasius profile at the inlet upstream from the step).
For the Blasius example in Nek, I used VisIt and checked rhs and psi from the stfc0.f* file, but psi does not  look physical.
1. What is the purpose of using v2mask? I wonder whether I should specify a different mask...
2. Including declarations from 'INPUT', 'SOLN', and 'MASS' produced a long list of errors (please see below).  To run the code, I commented three lines related to including 'INPUT', 'SOLN', and 'MASS'so that these are not included, but I wonder whether that would create problems?
Any advice would be appreciated.
Thanks very much.
Hannah
INPUT:14:16: Error: Symbol ‘param’ at (1) already has basic type of REAL
INPUT:22:27: Error: Symbol ‘param’ at (1) is already in a COMMON block
INPUT:25:20: Error: Symbol ‘matype’ at (1) already has basic type of INTEGER
INPUT:30:28: Error: Symbol ‘matype’ at (1) is already in a COMMON block
INPUT:34:26: Error: Symbol ‘if3d’ at (1) already has basic type of LOGICAL
INPUT:50:26: Error: Symbol ‘if3d’ at (1) is already in a COMMON block
INPUT:66:27: Error: Symbol ‘ifnav’ at (1) already has basic type of LOGICAL
INPUT:69:27: Error: Symbol ‘hcode’ at (1) already has basic type of CHARACTER
INPUT:70:27: Error: Symbol ‘ocode’ at (1) already has basic type of CHARACTER
INPUT:71:27: Error: Symbol ‘drivc’ at (1) already has basic type of CHARACTER
INPUT:72:26: Error: Symbol ‘rstv’ at (1) already has basic type of CHARACTER
INPUT:73:28: Error: Symbol ‘textsw’ at (1) already has basic type of CHARACTER
INPUT:74:27: Error: Symbol ‘initc’ at (1) already has basic type of CHARACTER
INPUT:75:27: Error: Symbol ‘hcode’ at (1) is already in a COMMON block
INPUT:77:29: Error: Symbol ‘turbmod’ at (1) already has basic type of CHARACTER
INPUT:80:28: Error: Symbol ‘reafle’ at (1) already has basic type of CHARACTER
INPUT:81:28: Error: Symbol ‘reafle’ at (1) is already in a COMMON block
INPUT:83:29: Error: Symbol ‘session’ at (1) already has basic type of CHARACTER
INPUT:84:29: Error: Symbol ‘session’ at (1) is already in a COMMON block
INPUT:86:20: Error: Symbol ‘cr_re2’ at (1) already has basic type of INTEGER
INPUT:87:33: Error: Symbol ‘cr_re2’ at (1) is already in a COMMON block
INPUT:89:24: Error: Symbol ‘re2off_b’ at (1) already has basic type of INTEGER
INPUT:90:31: Error: Symbol ‘re2off_b’ at (1) is already in a COMMON block
INPUT:94:13: Error: Symbol ‘xc’ at (1) already has basic type of REAL
INPUT:98:24: Error: Symbol ‘xc’ at (1) is already in a COMMON block
INPUT:100:20: Error: Symbol ‘igroup’ at (1) already has basic type of INTEGER
INPUT:101:28: Error: Symbol ‘igroup’ at (1) is already in a COMMON block
INPUT:103:28: Error: Symbol ‘ccurve’ at (1) already has basic type of CHARACTER
INPUT:104:25: Error: Symbol ‘cbc’ at (1) already has basic type of CHARACTER
INPUT:105:25: Error: Symbol ‘cbc’ at (1) is already in a COMMON block
INPUT:107:19: Error: Symbol ‘ieact’ at (1) already has basic type of INTEGER
INPUT:108:27: Error: Symbol ‘ieact’ at (1) is already in a COMMON block
INPUT:112:20: Error: Symbol ‘numsts’ at (1) already has basic type of INTEGER
INPUT:113:26: Error: PARAMETER attribute of ‘numsts’ conflicts with PARAMETER attribute at (1)
INPUT:115:20: Error: Symbol ‘numflu’ at (1) already has basic type of INTEGER
INPUT:118:29: Error: Symbol ‘numflu’ at (1) is already in a COMMON block
INPUT:121:17: Error: Symbol ‘bcf’ at (1) already has basic type of INTEGER
INPUT:122:26: Error: Symbol ‘bcf’ at (1) is already in a COMMON block
INPUT:124:24: Error: Symbol ‘bctyps’ at (1) already has basic type of CHARACTER
INPUT:125:29: Error: Symbol ‘bctyps’ at (1) is already in a COMMON block
SOLN:4:18: Error: Symbol ‘lvt1’ at (1) already has basic type of INTEGER
SOLN:5:41: Error: PARAMETER attribute of ‘lvt1’ conflicts with PARAMETER attribute at (1)
SOLN:6:41: Error: PARAMETER attribute of ‘lvt2’ conflicts with PARAMETER attribute at (1)
SOLN:7:45: Error: PARAMETER attribute of ‘lbt1’ conflicts with PARAMETER attribute at (1)
SOLN:8:45: Error: PARAMETER attribute of ‘lbt2’ conflicts with PARAMETER attribute at (1)
SOLN:10:42: Error: PARAMETER attribute of ‘lorder2’ conflicts with PARAMETER attribute at (1)
SOLN:14:13: Error: Symbol ‘bq’ at (1) already has basic type of REAL
SOLN:15:22: Error: Symbol ‘bq’ at (1) is already in a COMMON block
SOLN:18:16: Error: Symbol ‘vxlag’ at (1) already has basic type of REAL
SOLN:33:13: Error: Symbol ‘vx’ at (1) already has basic type of REAL
SOLN:52:27: Error: Symbol ‘vxlag’ at (1) is already in a COMMON block
SOLN:59:13: Error: Symbol ‘bx’ at (1) already has basic type of REAL
SOLN:78:13: Error: Symbol ‘bx’ at (1) is already in a COMMON block
SOLN:82:18: Error: Symbol ‘nu_star’ at (1) already has basic type of REAL
SOLN:83:29: Error: Symbol ‘nu_star’ at (1) is already in a COMMON block
SOLN:85:13: Error: Symbol ‘pr’ at (1) already has basic type of REAL
SOLN:86:22: Error: Symbol ‘pr’ at (1) is already in a COMMON block
SOLN:88:14: Error: Symbol ‘qtl’ at (1) already has basic type of REAL
SOLN:89:25: Error: Symbol ‘qtl’ at (1) is already in a COMMON block
SOLN:91:15: Error: Symbol ‘p0th’ at (1) already has basic type of REAL
SOLN:92:27: Error: Symbol ‘p0th’ at (1) is already in a COMMON block
SOLN:94:18: Error: Symbol ‘v1mask’ at (1) already has basic type of REAL
SOLN:106:28: Error: Symbol ‘v1mask’ at (1) is already in a COMMON block
SOLN:111:15: Error: Symbol ‘vxp’ at (1) already has basic type of REAL
SOLN:133:25: Error: Symbol ‘vxp’ at (1) is already in a COMMON block
SOLN:138:16: Error: Symbol ‘jp’ at (1) already has basic type of INTEGER
SOLN:139:25: Error: Symbol ‘jp’ at (1) is already in a COMMON block
MASS:4:14: Error: Symbol ‘bm1’ at (1) already has basic type of REAL
MASS:11:23: Error: Symbol ‘bm1’ at (1) is already in a COMMON block
/home/Hannah/NekExamples/blasius/c3.f:360:25:
       call compute_f (f1,w ,t )
                         1
Warning: Actual argument contains too few elements for dummy argument ‘w’ (1/4) at (1)
makefile:119: recipe for target 'nek5000' failed
make: *** [nek5000] Error 1
From: Nek5000-users [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Thursday, July 12, 2018 3:37 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Stream function
Ok, so can you please just try the attached code in userchck? It should
work (at least does for us) in 2D. Essentially, the steps are:
1. copmute z-vorticity in a new array vorticity
2. construct the rhs by multiplying with -bm1
3. setup the Helmholtz problem and tolerances
4. solve the Helmholtz problem and storing the results in a new array phi
5. write out everything in two files.
In this code you do not use the temperature at all, which I guess is
fine for a 2D case (which I guess is what you look at).
best regards,
Philipp
On 2018-07-10 22:33, Philipp Schlatter wrote:
> Dear Hannah,
> sorry that I only see the post now. Are you still having problems with
> the stream function, or does it work now?
> Best regards,
> Philipp
> On 2018-07-02 16:40, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi JC,
>> Yes, the mv_wall example computes the streamfunction, but it applies
>> tmask, tmult that I could not find where they are defined in the
>> file.  I was experimenting with different masks.
>> Do you know how postnek compute the streamfunction?
>> I think it is computed in the subroutine strfct(psi) in postnek2.f,
>> but I am not sure what happens in the routine?
>> Thanks,
>> Hannah
>> Sent: Friday, June 29, 2018 3:47 AM
>> Hi Hannah,
>> I tried to implement the streamfunction as well (for a 2D cylinder flow)
>> and it would appear that, doing naïvely, the tmask is set to zero
>> everywhere. Hence, when rhs * tmask is computed in the hmholtz
>> subroutine, rhs is set to zero everywhere and it then makes sense that
>> the returned streamfunction is zero everywhere as well.
>> Not sure how to do fix this properly though. Any help would be
>> appreciated indeed :)
>> JC
>> On 06/28/2018 09:41 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Philipp,
>>> Thanks very much for your comments.  Yes, the delta* works only for
>>> the parallel plate.
>>> The streamfunction computation with the Blasius example is still not
>>> working. I suspect I am not using the correct mask (vmult /tmult,
>>> imsh as well).
>>> Using the Blasius example, v1mask, vmult (imsh = 1), I dumped the
>>> streamfuntion to the temperature field. However, it only contains
>>> negative values and does not look physical (I pasted userchk below).
>>> Another Nek Example, “mv_wall”, computes the streamfunction from the
>>> Possison equation using vorticity. It uses tmask, tmult, and imsh = 2.
>>> I tried implementing what was done in the “mv_wall” example in the
>>> Blasius example, but the computed streamfunction is zero everywhere.
>>> Any ideas what I might be doing wrong?
>>> Any advice would be appreciated!
>>> Thanks again,
>>> Hannah
>>> c-----------------------------------------------------------------------
>>>         subroutine userchk
>>>         include 'SIZE'
>>>         include 'TOTAL'
>>>         common /myblas/ ub(lx1,ly1,lz1,lelt),vb(lx1,ly1,lz1,lelt)
>>>         common /blasiusr/ u(lx1,ly1,lz1,lelv),v(lx1,ly1,lz1,lelv)
>>>         common /blasiusg/ bin(lx1,ly1,lz1,lelv)
>>>         common /scrns/    dum(lx1*ly1*lz1*lelv)
>>>         common /xtream/ psi(lx1*ly1*lz1*lelt)
>>>        $              , rhs(lx1*ly1*lz1*lelt)
>>>        $              , h1 (lx1*ly1*lz1*lelt)
>>>        $              , h2 (lx1*ly1*lz1*lelt)
>>>         parameter (lt=lx1*ly1*lz1*lelt)
>>>         common /scrns/ vort(lt,3),w1(lt),w2(lt)
>>>         integer bin
>>>         real normu(50),normv(50)
>>>         real xmax,xmin,dx
>>>         save xmax,xmin,dx
>>>         n = nx1*ny1*nz1*nelv
>>>         ifheat=.false.
>>>         call comp_vort3(vort , w1, w2, vx, vy, vz)
>>>         call copy (t,vort,n)   ! Vorticity --> T
>>>         ifto = .true.          ! Dump vorticity as T
>>> c . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
>>> c     Compute streamfunction from vorticity
>>>         call col3 (rhs,t,bm1,n) ! B*omega
>>>         call rone (h1,n)
>>>         call rzero(h2,n)
>>>         ifield = 1
>>>         tol    = param(22)
>>>         imsh   = 1
>>>         call hmholtz('psi ',psi,rhs,h1,h2,v1mask,vmult,imsh,
>>>        $        tol,200,1)
>>>         call copy (t,psi,n)    ! Psi --> T (for output)
>>> c. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
>>>         nfldt = 1 + npscal
>>>         if (istep.eq.0) call outpost2(vx,vy,vz,pr,t,nfldt,'   ')
>>>         do i=1,n
>>>            dum(i) = 1.-vx(i,1,1,1)
>>>         enddo
>>>         tot_deficit = glsc2(dum,bm1,n)
>>>         xmin        = glmin(xm1,n)
>>>         xmax        = glmax(xm1,n)
>>>         delta_star  = tot_deficit/(xmax-xmin)
>>>         tmin        = glmin(t,n)
>>>         tmax        = glmax(t,n)
>>>         vortmin      = glmin(vort,n)
>>>         vortmax      = glmax(vort,n)
>>>         if (nid.eq.0) write(6,1) istep,time,delta_star,vortmin,vortmax
>>>         if (nid.eq.0) write(6,1) istep,tmin,tmax
>>>       1 format(i8,1p4e13.5,'  blasius: delta*')
>>>         return
>>>         end
>>> Sent: Tuesday, June 26, 2018 1:22 PM
>>> Hi,
>>> To correctly compute the stream function, the rhs of the Poisson
>>> equation needs to be the (negative) vorticity. Therefore, the line
>>>       call col2(rhs,bm1,n)
>>> is wrong, and should be something like
>>>       call col3(rhs, vorticity, bm1, n)
>>> where vorticity should be the computed vorticity using comp_vort.
>>> I guess your calculation of delta* only works for parallel boundary
>>> layers.
>>> Philipp
>>> On 2018-06-26 18:35, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Phillip,
>>>> I am using the “Blasius” example test outputting the streamfunction
>>>> as a
>>>> scalar.
>>>> I included my code below. I am not sure what I am doing wrong.
>>>> In userchk, I added “compute streamfunction from vorticity” from the
>>>> psi_omega example, but it does not compute the psi properly… (max_psi =
>>>> min_psi = 0 in every step)
>>>>          subroutine userchk
>>>>          include 'SIZE'
>>>>          include 'TOTAL'
>>>>          integer bin
>>>>          real xmax,xmin,dx
>>>>          save xmax,xmin,dx
>>>>          call rone (h1 ,n)
>>>>          call rzero(h2 ,n)
>>>>          tol = param(22)
>>>>          imsh   = 1
>>>>          call hmholtz('psi ',psi,rhs,h1,h2,v1mask,vmult,imsh,tol,200,1)
>>>>          if (istep.eq.0) call outpost(vx,vy,vz,pr,psi,'   ')
>>>> c     Compute delta*
>>>>          do i=1,n
>>>>          enddo
>>>>          xmin        = glmin(xm1,n)
>>>>          xmax        = glmax(xm1,n)
>>>>          psimin      = glmin(psi,n)
>>>>          psimax      = glmax(psi,n)
>>>>          if (nid.eq.0) write(6,1) istep,time,delta_star,psimin,psimax
>>>>          return
>>>>          end
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
