[Nek5000-users] Stream function
Tue Jul 10 15:33:14 CDT 2018
Dear Hannah,
sorry that I only see the post now. Are you still having problems with
the stream function, or does it work now?
Best regards,
Philipp
On 2018-07-02 16:40, nek5000-users at lists.mcs.anl.gov wrote:
> Hi JC,
> Yes, the mv_wall example computes the streamfunction, but it applies tmask, tmult that I could not find where they are defined in the file.  I was experimenting with different masks.
> Do you know how postnek compute the streamfunction?
> I think it is computed in the subroutine strfct(psi) in postnek2.f, but I am not sure what happens in the routine?
> Thanks,
> Hannah
> From: Nek5000-users [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Friday, June 29, 2018 3:47 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Stream function
> Hi Hannah,
> I tried to implement the streamfunction as well (for a 2D cylinder flow)
> and it would appear that, doing naïvely, the tmask is set to zero
> everywhere. Hence, when rhs * tmask is computed in the hmholtz
> subroutine, rhs is set to zero everywhere and it then makes sense that
> the returned streamfunction is zero everywhere as well.
> Not sure how to do fix this properly though. Any help would be
> appreciated indeed :)
> JC
> On 06/28/2018 09:41 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Philipp,
>> Thanks very much for your comments.  Yes, the delta* works only for the parallel plate.
>> The streamfunction computation with the Blasius example is still not working. I suspect I am not using the correct mask (vmult /tmult, imsh as well).
>> Using the Blasius example, v1mask, vmult (imsh = 1), I dumped the streamfuntion to the temperature field. However, it only contains negative values and does not look physical (I pasted userchk below).
>> Another Nek Example, “mv_wall”, computes the streamfunction from the Possison equation using vorticity. It uses tmask, tmult, and imsh = 2.
>> I tried implementing what was done in the “mv_wall” example in the Blasius example, but the computed streamfunction is zero everywhere.
>> Any ideas what I might be doing wrong?
>> Any advice would be appreciated!
>> Thanks again,
>> Hannah
>> c-----------------------------------------------------------------------
>>         subroutine userchk
>>         include 'SIZE'
>>         include 'TOTAL'
>>         common /myblas/ ub(lx1,ly1,lz1,lelt),vb(lx1,ly1,lz1,lelt)
>>         common /blasiusr/ u(lx1,ly1,lz1,lelv),v(lx1,ly1,lz1,lelv)
>>         common /blasiusg/ bin(lx1,ly1,lz1,lelv)
>>         common /scrns/    dum(lx1*ly1*lz1*lelv)
>>         common /xtream/ psi(lx1*ly1*lz1*lelt)
>>        $              , rhs(lx1*ly1*lz1*lelt)
>>        $              , h1 (lx1*ly1*lz1*lelt)
>>        $              , h2 (lx1*ly1*lz1*lelt)
>>         parameter (lt=lx1*ly1*lz1*lelt)
>>         common /scrns/ vort(lt,3),w1(lt),w2(lt)
>>         integer bin
>>         real normu(50),normv(50)
>>         real xmax,xmin,dx
>>         save xmax,xmin,dx
>>         n = nx1*ny1*nz1*nelv
>>         ifheat=.false.
>>         call comp_vort3(vort , w1, w2, vx, vy, vz)
>>         call copy (t,vort,n)   ! Vorticity --> T
>>         ifto = .true.          ! Dump vorticity as T
>> c . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
>> c     Compute streamfunction from vorticity
>>         call col3 (rhs,t,bm1,n) ! B*omega
>>         call rone (h1,n)
>>         call rzero(h2,n)
>>         ifield = 1
>>         tol    = param(22)
>>         imsh   = 1
>>         call hmholtz('psi ',psi,rhs,h1,h2,v1mask,vmult,imsh,
>>        $        tol,200,1)
>>         call copy (t,psi,n)    ! Psi --> T (for output)
>> c. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
>>         nfldt = 1 + npscal
>>         if (istep.eq.0) call outpost2(vx,vy,vz,pr,t,nfldt,'   ')
>>         do i=1,n
>>            dum(i) = 1.-vx(i,1,1,1)
>>         enddo
>>         tot_deficit = glsc2(dum,bm1,n)
>>         xmin        = glmin(xm1,n)
>>         xmax        = glmax(xm1,n)
>>         delta_star  = tot_deficit/(xmax-xmin)
>>         tmin        = glmin(t,n)
>>         tmax        = glmax(t,n)
>>         vortmin      = glmin(vort,n)
>>         vortmax      = glmax(vort,n)
>>         if (nid.eq.0) write(6,1) istep,time,delta_star,vortmin,vortmax
>>         if (nid.eq.0) write(6,1) istep,tmin,tmax
>>       1 format(i8,1p4e13.5,'  blasius: delta*')
>>         return
>>         end
>> Sent: Tuesday, June 26, 2018 1:22 PM
>> Hi,
>> To correctly compute the stream function, the rhs of the Poisson
>> equation needs to be the (negative) vorticity. Therefore, the line
>>       call col2(rhs,bm1,n)
>> is wrong, and should be something like
>>       call col3(rhs, vorticity, bm1, n)
>> where vorticity should be the computed vorticity using comp_vort.
>> I guess your calculation of delta* only works for parallel boundary layers.
>> Philipp
>> On 2018-06-26 18:35, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Phillip,
>>> I am using the “Blasius” example test outputting the streamfunction as a
>>> scalar.
>>> I included my code below. I am not sure what I am doing wrong.
>>> In userchk, I added “compute streamfunction from vorticity” from the
>>> psi_omega example, but it does not compute the psi properly… (max_psi =
>>> min_psi = 0 in every step)
>>>          subroutine userchk
>>>          include 'SIZE'
>>>          include 'TOTAL'
>>>          integer bin
>>>          real xmax,xmin,dx
>>>          save xmax,xmin,dx
>>>          call rone (h1 ,n)
>>>          call rzero(h2 ,n)
>>>          tol = param(22)
>>>          imsh   = 1
>>>          call hmholtz('psi ',psi,rhs,h1,h2,v1mask,vmult,imsh,tol,200,1)
>>>          if (istep.eq.0) call outpost(vx,vy,vz,pr,psi,'   ')
>>> c     Compute delta*
>>>          do i=1,n
>>>          enddo
>>>          xmin        = glmin(xm1,n)
>>>          xmax        = glmax(xm1,n)
>>>          psimin      = glmin(psi,n)
>>>          psimax      = glmax(psi,n)
>>>          if (nid.eq.0) write(6,1) istep,time,delta_star,psimin,psimax
>>>          return
>>>          end
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
