[Nek5000-users] 'Divergence' using low-Mach number solver
Wed Jan 31 07:09:30 CST 2018
I quickly looked at your *.usr file and you use variable properties as expected for low Mach flow, but you do not seem to make the distinction between velocity equation and heat equation. I believe you have to use the same syntax as in usrbc where you test the field index and set the property.
Marco
On Jan 30, 2018, at 12:24 PM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180131/0ee1a1fb/attachment.html>
Desc: vd.par
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180131/0ee1a1fb/attachment.obj>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180131/0ee1a1fb/attachment.htm>
