[Nek5000-users] turbChannel compiling issue after adding more elements
Thu Jan 25 02:00:57 CST 2018
Are you using the mesh from the example otherwise you have to create new AMG files for your mesh.
See here: https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2017-December/004854.html
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 25th January 2018 5:58
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] turbChannel compiling issue after adding more elements
> Hi Ming & everyone,
> I tracked down the error to a part of the gslib code (Nek5000/3rd_party/gslib/gslib-1.0.1/src/amg.c:487). Unfortunately, I am not familiar with AMG or gslib code so I cannot help you with this problem.
> If someone is familiar with this issue, please help Ming out.
> Sincerely,
> Kento
> > On Jan 24, 2018, at 22:40, nek5000-users at lists.mcs.anl.gov wrote:
> > Hello Kento,
> > Thank you for your help! The compiler now works. But I ran into another issue; after it started to run, it soon stopped and reported an error saying:
> > AMG: preading through rows ... done
> > ERROR (proc 0000, src/amg.c:487): AMG: missing data for some rows
> > an error occured: dying …
> > Would you run into this issue earlier before?
> > Again thanks a lot for the suggestions.
> > Regards,
> > Ming
> > *********** complete logfile *********
> > Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.par
> > general = [(null)]
> > general:stopat = [endTime]
> > general:endtime = [200]
> > general:dt = [0]
> > general:timestepper = [bdf2]
> > general:extrapolation = [OIFS]
> > general:variabledt = [yes]
> > general:targetcfl = [2.0]
> > general:writecontrol = [runTime]
> > general:writeinterval = [200.0]
> > general:userparam01 = [100]
> > general:userparam02 = [20]
> > general:userparam03 = [1]
> > general:filtering = [hpfrt]
> > general:filterweight = [10]
> > general:filtercutoffratio = [0.9]
> > problemtype = [(null)]
> > problemtype:variableproperties = [no]
> > problemtype:equation = [incompNS]
> > pressure = [(null)]
> > pressure:preconditioner = [semg_amg]
> > pressure:residualtol = [1e-04]
> > pressure:residualproj = [yes]
> > velocity = [(null)]
> > velocity:residualtol = [1e-07]
> > velocity:density = [1]
> > velocity:viscosity = [-10900]
> >  Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.re2
> >  mapping elements to processors
> >  Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.ma2
> >            0        9216        9216       73728       73728  NELV
> >            5        9216        9216       73728       73728  NELV
> >            7        9216        9216       73728       73728  NELV
> >            1        9216        9216       73728       73728  NELV
> >            3        9216        9216       73728       73728  NELV
> >            6        9216        9216       73728       73728  NELV
> >            4        9216        9216       73728       73728  NELV
> >            2        9216        9216       73728       73728  NELV
> >  element load imbalance:            0        9216        9216
> >  done :: mapping   0.66962E-01 sec
> >   preading mesh
> >   preading bc for ifld           1
> >  done :: read .re2 file   0.30     sec
> >  nelgt/nelgv/lelt:       73728       73728       18439
> >  lx1  /lx2  /lx3 :           8           8           8
> >  setup mesh topology
> >    Right-handed check complete for   73728 elements. OK.
> >    setvert3d:   8     9476352    25401600     9476352     9476352
> >  call usrsetvert
> >  done :: usrsetvert
> > gs_setup: 413952 unique labels shared
> >    pairwise times (avg, min, max): 0.000140989 0.000133355 0.000146356
> >    crystal router                : 0.0012817 0.00128028 0.00128291
> >    used all_to_all method: pairwise
> >    handle bytes (avg, min, max): 3.26526e+07 32652644 32652644
> >    buffer bytes (avg, min, max): 1.68269e+06 1682688 1682688
> >    setupds time 1.9997E+00 seconds   0  8     9476352       73728
> >            8  max multiplicity
> >  done :: setup mesh topology
> >  call usrdat
> >  done :: usrdat
> >  generate geometry data
> >  NOTE: All elements deformed , param(59) ^=0
> >  done :: generate geometry data
> >  call usrdat2
> >  done :: usrdat2
> >  regenerate geometry data           1
> >  done :: regenerate geometry data           1
> >  verify mesh topology
> >   0.000000000000000E+000   6.28318530717959       Xrange
> >   -1.00000000000000        1.00000000000000       Yrange
> >   0.000000000000000E+000   3.14159265358979       Zrange
> >  done :: verify mesh topology
> >  IFTRAN   = T
> >  IFFLOW   = T
> >  IFHEAT   = F
> >  IFSPLIT  = T
> >  IFLOMACH = F
> >  IFUSERVP = F
> >  IFUSERMV = F
> >  IFPERT   = F
> >  IFADJ    = F
> >  IFSTRS   = F
> >  IFCHAR   = T
> >  IFCYCLIC = F
> >  IFAXIS   = F
> >  IFMVBD   = F
> >  IFMELT   = F
> >  IFNEKNEK = F
> >  IFSYNC   = F
> >  IFVCOR   = T
> >  IFINTQ   = F
> >  IFGEOM   = F
> >  IFSURT   = F
> >  IFWCNO   = F
> >  IFTMSH for field           1    =  F
> >  IFADVC for field           1    =  T
> >  IFNONL for field           1    =  F
> >  Dealiasing enabled, lxd=           8
> >  Estimated eigenvalues
> >  EIGAA =    1.23913370009078
> >  EIGGA =    30588693.2337829
> >  EIGAE =   0.250000000000000
> >  EIGAS =   1.681282119258565E-002
> >  EIGGE =    30588693.2337829
> >  EIGGS =    2.00000000000000
> >   E-solver strategy:  0 itr
> >  mg_nx:           1           3           7
> >  mg_ny:           1           3           7
> >  mg_nz:           1           3           7
> >  call usrsetvert
> >  done :: usrsetvert
> > gs_setup: 8448 unique labels shared
> >    pairwise times (avg, min, max): 1.21617e-05 1.1921e-05 1.24227e-05
> >    crystal router                : 3.65702e-05 3.65344e-05 3.66269e-05
> >    all reduce                    : 0.00014386 0.000142943 0.000144376
> >    handle bytes (avg, min, max): 728420 728420 728420
> >    buffer bytes (avg, min, max): 37632 37632 37632
> >    setupds time 2.0250E-02 seconds   1  2       76032       73728
> >    setvert3d:   4     1421568     2011392     1421568     1421568
> >  call usrsetvert
> >  done :: usrsetvert
> > gs_setup: 76032 unique labels shared
> >    pairwise times (avg, min, max): 4.62178e-05 4.47887e-05 4.74119e-05
> >    crystal router                : 0.000222897 0.000222723 0.000223086
> >    all reduce                    : 0.000974339 0.000967893 0.000979289
> >    handle bytes (avg, min, max): 5.91396e+06 5913956 5913956
> >    buffer bytes (avg, min, max): 315648 315648 315648
> >    setupds time 3.5739E-01 seconds   2  4     1421568       73728
> >  call usrsetvert
> >  done :: usrsetvert
> >    pairwise times (avg, min, max): 4.5131e-05 4.40137e-05 4.5883e-05
> >    crystal router                : 0.000217508 0.00021732 0.000217639
> >    all reduce                    : 0.000978618 0.000972797 0.000983269
> >    setupds time 3.5094E-01 seconds   3  4     1421568       73728
> >    setvert3d:   6     4555008     9273600     4555008     4555008
> >  call usrsetvert
> >  done :: usrsetvert
> > gs_setup: 211200 unique labels shared
> >    pairwise times (avg, min, max): 9.59221e-05 9.2321e-05 9.80701e-05
> >    crystal router                : 0.000574208 0.000573776 0.000574501
> >    handle bytes (avg, min, max): 1.65554e+07 16555364 16555364
> >    buffer bytes (avg, min, max): 864000 864000 864000
> >    setupds time 9.2152E-01 seconds   4  6     4555008       73728
> >  h1_mg_nx:           1           3           7
> >  h1_mg_ny:           1           3           7
> >  h1_mg_nz:           1           3           7
> >  call usrsetvert
> >  done :: usrsetvert
> >    pairwise times (avg, min, max): 1.42743e-05 1.37607e-05 1.47085e-05
> >    crystal router                : 3.54692e-05 3.53276e-05 3.56395e-05
> >    all reduce                    : 0.000145775 0.000145112 0.000146347
> >    setupds time 1.9277E-02 seconds   5  2       76032       73728
> >  call usrsetvert
> >  done :: usrsetvert
> >    pairwise times (avg, min, max): 4.74352e-05 4.61341e-05 4.8379e-05
> >    crystal router                : 0.000219904 0.000219596 0.000220055
> >    all reduce                    : 0.00108293 0.00107907 0.00108614
> >    setupds time 3.5849E-01 seconds   6  4     1421568       73728
> >  call usrsetvert
> >  done :: usrsetvert
> >    pairwise times (avg, min, max): 4.99966e-05 4.93097e-05 5.04928e-05
> >    crystal router                : 0.000220982 0.000220777 0.000221201
> >    all reduce                    : 0.000975639 0.000969762 0.000980587
> >    setupds time 3.5221E-01 seconds   7  4     1421568       73728
> >  call usrsetvert
> >  done :: usrsetvert
> >    pairwise times (avg, min, max): 9.7033e-05 9.53629e-05 9.89481e-05
> >    crystal router                : 0.000575673 0.000575274 0.00057601
> >    setupds time 9.0969E-01 seconds   8  6     4555008       73728
> >  call usrsetvert
> >  done :: usrsetvert
> >    pairwise times (avg, min, max): 0.000145018 0.00014225 0.000147666
> >    crystal router                : 0.00127508 0.00127457 0.00127577
> >    setupds time 1.9358E+00 seconds   9  8     9476352       73728
> >    setvert3d:  10    16185600    53934336    16185600    16185600
> >  call usrsetvert
> >  done :: usrsetvert
> > gs_setup: 684288 unique labels shared
> >    pairwise times (avg, min, max): 0.000185176 0.000182058 0.000188558
> >    crystal router                : 0.00236343 0.00236093 0.00236685
> >    handle bytes (avg, min, max): 5.42058e+07 54205796 54205796
> >    buffer bytes (avg, min, max): 2.77171e+06 2771712 2771712
> >    setupds time 3.2958E+00 seconds  10 10    16185600       73728
> >  setup h1 coarse grid, nx_crs=           2
> >  call usrsetvert
> >  done :: usrsetvert
> >    pairwise times (avg, min, max): 1.58059e-05 1.48741e-05 1.6321e-05
> >    crystal router                : 3.54276e-05 3.51642e-05 3.56729e-05
> >    all reduce                    : 0.000144706 0.000143665 0.00014533
> >    pairwise times (avg, min, max): 1.56632e-05 1.53686e-05 1.61476e-05
> >    crystal router                : 1.74988e-05 1.74323e-05 1.75631e-05
> >    all reduce                    : 0.000148094 0.00014731 0.000148594
> >    handle bytes (avg, min, max): 368228 368228 368228
> >    buffer bytes (avg, min, max): 17664 17664 17664
> > AMG version 2.01
> > AMG: 8 levels
> > AMG Chebyshev smoother data:
> > AMG  level 1: 3 iterations with rho = 0.79256
> > AMG  level 2: 2 iterations with rho = 0.668297
> > AMG  level 3: 2 iterations with rho = 0.481307
> > AMG  level 4: 2 iterations with rho = 0.409707
> > AMG  level 5: 2 iterations with rho = 0.458605
> > AMG  level 6: 3 iterations with rho = 0.696293
> > AMG  level 7: 2 iterations with rho = 0.666743
> > AMG: 1664 rows
> > an error occured: dying ...
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
