[Nek5000-users] Periodicity with curvature
Sat Jan 13 13:00:48 CST 2018
My apologies, can you clarify what you mean?
I made global refinements one more time, and re-assigned the periodic BCs
within prex. For this 2D case (attached), I have linked the 8 element sides
with the right 8 sides. All other sides are walls.
Thank you,
Jon
On Sat, Jan 13, 2018 at 12:49 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> can you try again with at least 3 elements in other direction.
> On 13 Jan 2018, at 19:42, "nek5000-users at lists.mcs.anl.gov" <
> Thanks for the quick response. I made some global refinements but it seems
> I'm still getting the same error with genmap.
> Attached is the new .rea file with 4 elements in the periodic direction.
> On Sat, Jan 13, 2018 at 12:32 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> You need to have at least three elements in the periodic direction.
>> On 13 Jan 2018, at 19:19, "nek5000-users at lists.mcs.anl.gov" <
>> Dear Nek Users,
>> I am trying to get periodicity to work in the lastest version of Nek.
>> I've made an extremely simple mesh within prenek (prex) in polar
>> coordinates and cannot seem to run this case. When I run genmap, I get the
>> error below. Did I do something wrong in setting up this mesh?
>> >> genmap
>>  reading a.rea
>> Input mesh tolerance (default 0.2):
>> NOTE: smaller is better, but generous is more forgiving for bad meshes.
>> 0.01
>>  reading mesh data ...
>>  start locglob_lexico:           4           2           8
>>  1.0000000000000000E-002
>>  locglob:           1           1           8
>>  locglob:           2           5           8
>>  locglob:           1           6           8
>>  locglob:           2           6           8
>>  done locglob_lexico:           6           6           8           2
>>  start periodic vtx:           2           6
>>      1     4     4  Matrix:    x0
>>   1   x0    1.0000E+00  1.0000E+00  5.4347-323  4.9407-324
>>   2   x0   -3.5355E-01  3.5355E-01  6.9423-310  6.9423-310
>>   3   x0    3.5355E-01 -3.5355E-01  6.9529-310  6.9529-310
>>   4   x0    6.9423-310  6.9529-310  2.3477-313  3.1632-317
>>      2     4     4  Matrix:    x1
>>   1   x1    1.0000E+00  1.0000E+00  6.3240-322  0.0000E+00
>>   2   x1   -3.5355E-01  3.5355E-01  0.0000E+00  6.9423-310
>>   3   x1   -3.5355E-01  3.5355E-01  6.9423-310  6.9529-310
>>   4   x1    6.9423-310  6.9423-310  6.9423-310  6.9529-310
>>      1     4     4  Matrix:    z0
>>   1   z0    1.0000E+00  1.0000E+00  5.4347-323  4.9407-324
>>   2   z0   -2.1213E+00 -1.4142E+00  6.9423-310  6.9423-310
>>   3   z0    2.1213E+00  1.4142E+00  6.9529-310  6.9529-310
>>   4   z0    6.9423-310  6.9529-310  2.3477-313  3.1632-317
>>      2     4     4  Matrix:    z1
>>   1   z1    1.0000E+00  1.0000E+00  6.3240-322  0.0000E+00
>>   2   z1    1.4142E+00  2.1213E+00  0.0000E+00  6.9423-310
>>   3   z1    1.4142E+00  2.1213E+00  6.9423-310  6.9529-310
>>   4   z1    6.9423-310  6.9423-310  6.9423-310  6.9529-310
>>            1 3  0  1.00000000E-03  2.12132000E+00 abort: FACE MATCH FAIL
>>            2 4  3  2.12132000E-03  1.00000031E+00 abort: FACE MATCH FAIL
>>            0  quit
>> The mesh within my .rea file is as follows:
>>    20.0000       20.0000      -8.00000      -4.00000
>>  XFAC,YFAC,XZERO,YZERO
>>  **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
>>          2         2         2 NEL,NDIM,NELV
>>       ELEMENT          1 [    1A]    GROUP     0
>>   -2.121320      -1.414213     -0.8742276E-07 -0.1311341E-06
>>    2.121320       1.414213       2.000000       3.000000
>>       ELEMENT          2 [    1B]    GROUP     0
>>  -0.1311341E-06 -0.8742276E-07   1.414213       2.121320
>>    3.000000       2.000000       1.414213       2.121320
>>   ***** CURVED SIDE DATA *****
>>          4 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
>>   2  1  -2.00000       0.00000       0.00000       0.00000       0.00000
>>    C
>>   4  1   3.00000       0.00000       0.00000       0.00000       0.00000
>>    C
>>   2  2  -2.00000       0.00000       0.00000       0.00000       0.00000
>>    C
>>   4  2   3.00000       0.00000       0.00000       0.00000       0.00000
>>    C
>>   ***** BOUNDARY CONDITIONS *****
>>   ***** FLUID   BOUNDARY CONDITIONS *****
>>  P    1  1   2.00000       3.00000       0.00000       0.00000
>>  0.00000
>>  W    1  2   0.00000       0.00000       0.00000       0.00000
>>  0.00000
>>  E    1  3   2.00000       1.00000       0.00000       0.00000
>>  0.00000
>>  W    1  4   0.00000       0.00000       0.00000       0.00000
>>  0.00000
>>  E    2  1   1.00000       3.00000       0.00000       0.00000
>>  0.00000
>>  W    2  2   0.00000       0.00000       0.00000       0.00000
>>  0.00000
>>  P    2  3   1.00000       1.00000       0.00000       0.00000
>>  0.00000
>>  W    2  4   0.00000       0.00000       0.00000       0.00000
>>  0.00000
>>   ***** NO THERMAL BOUNDARY CONDITIONS *****
>> <mime-attachment.png>
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.mcs.anl.gov_mailman_listinfo_nek5000-2Dusers&d=DwMFaQ&c=ODFT-G5SujMiGrKuoJJjVg&r=gP2CkfxBOr64FG89YpFokg&m=ncKzoPY2dwLIbAc1FITAEJsCsTeH2zRgDAqkjXYZe5A&s=nLM4v-0kL5jW9dMNEgiVqdVGDFSs6TFHQxJK53ePw04&e=>
>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.mcs.anl.gov_mailman_listinfo_nek5000-2Dusers&d=DwMFaQ&c=ODFT-G5SujMiGrKuoJJjVg&r=gP2CkfxBOr64FG89YpFokg&m=BAFsct9orEUodBvhKrXssNMVdu-OcqgveZCrA11i8M8&s=DBQt47t5SSmsVmTy3GCoo7VqaiTms-bCOKWC0nrs9xo&e=>
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.mcs.anl.gov_mailman_listinfo_nek5000-2Dusers&d=DwMFaQ&c=ODFT-G5SujMiGrKuoJJjVg&r=gP2CkfxBOr64FG89YpFokg&m=BAFsct9orEUodBvhKrXssNMVdu-OcqgveZCrA11i8M8&s=DBQt47t5SSmsVmTy3GCoo7VqaiTms-bCOKWC0nrs9xo&e=>
> <a.rea>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180113/dc23ddae/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180113/dc23ddae/attachment-0001.obj>
