[Nek5000-users] Periodicity with curvature
Sat Jan 13 12:41:57 CST 2018
Thanks for the quick response. I made some global refinements but it seems
I'm still getting the same error with genmap.
Attached is the new .rea file with 4 elements in the periodic direction.
On Sat, Jan 13, 2018 at 12:32 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> You need to have at least three elements in the periodic direction.
> On 13 Jan 2018, at 19:19, "nek5000-users at lists.mcs.anl.gov" <
> Dear Nek Users,
> I am trying to get periodicity to work in the lastest version of Nek. I've
> made an extremely simple mesh within prenek (prex) in polar coordinates and
> cannot seem to run this case. When I run genmap, I get the error below. Did
> I do something wrong in setting up this mesh?
> >> genmap
>  reading a.rea
> Input mesh tolerance (default 0.2):
> NOTE: smaller is better, but generous is more forgiving for bad meshes.
> 0.01
>  reading mesh data ...
>  start locglob_lexico:           4           2           8
>  1.0000000000000000E-002
>  locglob:           1           1           8
>  locglob:           2           5           8
>  locglob:           1           6           8
>  locglob:           2           6           8
>  done locglob_lexico:           6           6           8           2
>  start periodic vtx:           2           6
>      1     4     4  Matrix:    x0
>   1   x0    1.0000E+00  1.0000E+00  5.4347-323  4.9407-324
>   2   x0   -3.5355E-01  3.5355E-01  6.9423-310  6.9423-310
>   3   x0    3.5355E-01 -3.5355E-01  6.9529-310  6.9529-310
>   4   x0    6.9423-310  6.9529-310  2.3477-313  3.1632-317
>      2     4     4  Matrix:    x1
>   1   x1    1.0000E+00  1.0000E+00  6.3240-322  0.0000E+00
>   2   x1   -3.5355E-01  3.5355E-01  0.0000E+00  6.9423-310
>   3   x1   -3.5355E-01  3.5355E-01  6.9423-310  6.9529-310
>   4   x1    6.9423-310  6.9423-310  6.9423-310  6.9529-310
>      1     4     4  Matrix:    z0
>   1   z0    1.0000E+00  1.0000E+00  5.4347-323  4.9407-324
>   2   z0   -2.1213E+00 -1.4142E+00  6.9423-310  6.9423-310
>   3   z0    2.1213E+00  1.4142E+00  6.9529-310  6.9529-310
>   4   z0    6.9423-310  6.9529-310  2.3477-313  3.1632-317
>      2     4     4  Matrix:    z1
>   1   z1    1.0000E+00  1.0000E+00  6.3240-322  0.0000E+00
>   2   z1    1.4142E+00  2.1213E+00  0.0000E+00  6.9423-310
>   3   z1    1.4142E+00  2.1213E+00  6.9423-310  6.9529-310
>   4   z1    6.9423-310  6.9423-310  6.9423-310  6.9529-310
>            1 3  0  1.00000000E-03  2.12132000E+00 abort: FACE MATCH FAIL
>            2 4  3  2.12132000E-03  1.00000031E+00 abort: FACE MATCH FAIL
>            0  quit
> The mesh within my .rea file is as follows:
>    20.0000       20.0000      -8.00000      -4.00000
>  XFAC,YFAC,XZERO,YZERO
>  **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
>          2         2         2 NEL,NDIM,NELV
>       ELEMENT          1 [    1A]    GROUP     0
>   -2.121320      -1.414213     -0.8742276E-07 -0.1311341E-06
>    2.121320       1.414213       2.000000       3.000000
>       ELEMENT          2 [    1B]    GROUP     0
>  -0.1311341E-06 -0.8742276E-07   1.414213       2.121320
>    3.000000       2.000000       1.414213       2.121320
>   ***** CURVED SIDE DATA *****
>          4 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
>   2  1  -2.00000       0.00000       0.00000       0.00000       0.00000
>    C
>   4  1   3.00000       0.00000       0.00000       0.00000       0.00000
>    C
>   2  2  -2.00000       0.00000       0.00000       0.00000       0.00000
>    C
>   4  2   3.00000       0.00000       0.00000       0.00000       0.00000
>    C
>   ***** BOUNDARY CONDITIONS *****
>   ***** FLUID   BOUNDARY CONDITIONS *****
>  P    1  1   2.00000       3.00000       0.00000       0.00000
>  0.00000
>  W    1  2   0.00000       0.00000       0.00000       0.00000
>  0.00000
>  E    1  3   2.00000       1.00000       0.00000       0.00000
>  0.00000
>  W    1  4   0.00000       0.00000       0.00000       0.00000
>  0.00000
>  E    2  1   1.00000       3.00000       0.00000       0.00000
>  0.00000
>  W    2  2   0.00000       0.00000       0.00000       0.00000
>  0.00000
>  P    2  3   1.00000       1.00000       0.00000       0.00000
>  0.00000
>  W    2  4   0.00000       0.00000       0.00000       0.00000
>  0.00000
>   ***** NO THERMAL BOUNDARY CONDITIONS *****
> <mime-attachment.png>
> Nek5000-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.mcs.anl.gov_mailman_listinfo_nek5000-2Dusers&d=DwMFaQ&c=ODFT-G5SujMiGrKuoJJjVg&r=gP2CkfxBOr64FG89YpFokg&m=ncKzoPY2dwLIbAc1FITAEJsCsTeH2zRgDAqkjXYZe5A&s=nLM4v-0kL5jW9dMNEgiVqdVGDFSs6TFHQxJK53ePw04&e=>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180113/d6dd4beb/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180113/d6dd4beb/attachment-0001.obj>
