[Nek5000-users] Re post-processing using f0000 files
Thu Jan 11 15:03:19 CST 2018
Hi ZJ,
Yes I meant the hemi.usr case.
I just looked at the usr file that you attached in earlier message, and I don’t see any discrepancies in it. It should work for your case since it only averages in z direction and since your mesh was extruded using n2to3, the element numbering should be as expected.
Can you please make sure the value of nelxy i.e. number of elements in the 2D cross-section is correction. Right now it is set to 288 in the usr file.
Ketan
