[Nek5000-users] Question about iside value
Thu Jan 11 09:16:28 CST 2018
Hi Elizabeth,
userbc is called only for "v  " BCs (for velocity) or for "t  " (for temperature),
or other similar BCs that require user input.   "W   " BCs do not get passed
to userbc, nor do "O   ".
"o   " BCs do, however.
The rule is that lower case characters indicate user-defined values in userbc.
There is no lower case Wall BC, however.    Note that "W  " is effectively the
same as:
 "v   "
with ux=0, uy=0, uz=0.
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Wednesday, November 15, 2017 11:29:17 AM
To: nek5000-users
Subject: [Nek5000-users] Question about iside value
Hi, Neks!
I am working with a complex geometry witch was built in gambit. I want to know a parameter "iside" for each of faces ( outflow, inflow and all walls) on zero step. If I ask in userbc ( in *.usr file) write "iside", I receive only iside=1, that matches inflow. It means that faces with type "wall" don't have "iside" value,am i right?
And how each surface is assigned value "iside"?
Best regards,
Elizabeth
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180111/29c5bfbb/attachment.html>
