[Nek5000-users] Re post-processing using f0000 files
Tue Jan 9 15:42:26 CST 2018
Hi ZJ,
One thing to keep in mind for the averaging process is that it assumes the element numbering is lexicographic. I.e. elements are numbered sequentially in x, then y and then z. That being said, since your 2D mesh was generated in pretex, the numbering might not what the code was written for. If this is the case, a workaround would be to use the interp_uvw from the hemi case as an example to generate a set of say uniform points in your domain and then average the values at those points by using gslib_findpts_eval amd uniform weights, and writing them out to a dat file.
Ketan
Sent from my iPhone
