[Nek5000-users] Outputting to 2d VTK using Postnek
Fri Jan 5 14:59:19 CST 2018
Hi, everyone:
I am still having problems outputting 2d VTK files. I have tried modifying
the function vtk_out_hex() in postnek/trap.f (see attached file) by adding
an extra conditional for when mz == 1 (which is true for 2d). In this case,
I have simply copied the original code, but omitted the k loop and set k =
1.
When I do this, postnek will output the cell information for 2d simulations
(CELLS), although it is still outputting the 8 points per cell (3d) since I
am not sure which 4 of the 8 points might be correct for the 2d case. I
have tried visualizing the 2d VTK file using various combinations of the 4
points: (1,2,3,4), (5,6,7,8), (1,3,5,7), etc., but the results still do not
look correct.
I have attached the modified version of vtk_out_hex() that I have written.
I have also attached the VTK output that it produces: eddy_uv_mod.vtk.
I'm afraid I am a bit stuck here without better knowledge of the underlying
data structures in Nek. Any help or nudges in the correct direction are
appreciated!
Taiyo
On Wed, Dec 6, 2017 at 1:47 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi, all:
> I have run into problems using postnek/postex to convert simulation output
> to VTK format for 2d simulations (3d simulations work fine). I have tested
> this using the eddy_uv example from the NekExamples directory. When using
> postex, I use the option "DUMP vtk ALL", which produces the attached VTK
> output. It seems that the grid point position information is incorrect.
> Also, I have looked through the postnek functions in trap.f and it seems
> that VTK cell information (CELLS, CELL_TYPES) is omitted for 2d cases. Is
> there a way to output this information for 2d results?
> Perhaps there is something I am overlooking? Any help is greatly
> appreciated.
> Thanks,
> Taiyo
> Nek5000-users mailing list
Taiyo J. Wilson
Research Engineer
Illinois Rocstar LLC
108 Hessel Blvd.
Champaign, IL 61820
twilson at illinoisrocstar.com
www.illinoisrocstar.com
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180105/a6354433/attachment-0001.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180105/a6354433/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180105/a6354433/attachment-0001.obj>
